DHT-11 Spin Code
NWCCTV
So has anyone created an Object that has not been posted to the OBEX for this Temp/Humidity Sensor? I searched and could not find anything and have been trying to use the SHT-11 Object with no luck. I searched the Forums and found a few people had messed with it a couple years back but nothing since. Any suggestions or help is appreciated. Link to Data Sheet .pdf file is here: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.micropik.com%2FPDF%2Fdht11.pdf&ei=4zrxVOjZFY6pogSi7ILADw&usg=AFQjCNGd9WZqa-MaTqfueH6tRBNw_gTYHA&sig2=kiEOwxW72v5UkYquMJ4xxQ&bvm=bv.87269000,d.cGU
I don't know why you thought SHT-11 code would work with the DHT-11; the SHT-11 is a two-wire device, the DHT-11 is a one-wire device. Apples and oranges.
