Password help w/ Keypad & LCD — Parallax Forums
CambodiaCambodia Posts: 2
edited 2015-02-27 11:24 in BASIC Stamp
Hello! A friend of mine and I are having issues getting any code dealing with passwords and keypads to work. I have looked online and on this forum for weeks without luck. Could anyone help us? We’re using a 4x4 Matrix Membrane Keypad in pins 0-7 and a Parallax 2 x 16 Serial LCD (Non-Backlit) in pin 15. We know these two codes work:
LCD Code
' {$STAMP BS2}
' {$PBASIC 2.5}
TxPin     CON   15
n9600     CON   84
HIGH TxPin                       ' Set serial pin port high
PAUSE 100                        ' Pause to initialize
SEROUT TxPin, n9600, [12, 17]    ' Clear, turn on backlight
SEROUT TxPin, n9600, ["Hello, world...", 13] ' Print text, line feed
SEROUT TxPin, n9600, ["from Parallax!"]
SEROUT TxPin, n9600, [212, 220]  ' Quarter A note
PAUSE 3000                       ' Wait 3 seconds
SEROUT TxPin, n9600, [18]        ' Turn backlight off
Keypad Code
' {$STAMP BS2}
' {$PBASIC 2.5}
row         VAR  Nib                        ' Variable space for row counting
column      VAR  Nib                        ' Variable space for column counting
keypad      VAR  Word                       ' Variable space to store keypad output
keypadOld   VAR  Word                       ' Variable space to store old keypad output
temp        VAR  Nib                        ' Variable space for polling column states
DEBUG CLS                                   ' Clear Debug Terminal
GOSUB Update                                ' Display keypad graphic
DO
  GOSUB ReadKeypad                          ' Read keypad button states
  DEBUG HOME, BIN16 keypad, CR, CR,         ' Display 16-bit keypad value
              BIN4 keypad >> 12,CR,         ' Display 1st row 4-bit keypad value
              BIN4 keypad >> 8, CR,         ' Display 2nd row 4-bit keypad value
              BIN4 keypad >> 4, CR,         ' Display 3rd row 4-bit keypad value
              BIN4 keypad                   ' Display 4th row 4-bit keypad value
  IF keypad <> keypadOld THEN               ' If different button is pressed,
    GOSUB Update                            ' update the keypad graphic to clear
  ENDIF                                     ' old display
  IF keypad THEN                            ' Display button pressed in graphic
    GOSUB display
  ENDIF
  keypadOld = keypad                        ' Store keypad value in variable keypadOld
LOOP
' -----[ Subroutine - ReadKeypad ]-------------------------------------------------
ReadKeypad:
  keypad = 0
  OUTL   = %00000000                        ' Initialize IO
  DIRL   = %00000000
  FOR row = 0 TO 3
    DIRB = %1111                            ' Set columns (P7-P4) as outputs
    OUTB = %0000                            ' Pull columns low (act as pull down)
    OUTA = 1 << Row                         ' Set rows high one by one
    DIRA = 1 << Row
    temp = 0                                ' Reset temp variable to 0
    FOR column = 0 TO 3
      INPUT (column + 4)                    ' Set columns as inputs one by one
      temp = temp | (INB & (1 << column))   ' Poll column state and store in temp
    NEXT
    keypad = keypad << 4 | (Temp REV 4)     ' Store keypad value
  NEXT
RETURN
' -----[ Subroutine - Update ]-----------------------------------------------------
' Graphical depiction of keypad
Update:
  DEBUG CRSRXY,0,7,
    "+---+---+---+---+",CR,
    "|   |   |   |   |",CR,
    "|   |   |   |   |",CR,
    "|   |   |   |   |",CR,
    "|   |   |   |   |",CR,
RETURN
' -----[ Subroutine - Display ]----------------------------------------------------
' Display button pressed in keypad graphic
Display:
  IF KeyPad.BIT15 THEN  DEBUG CRSRXY, 02,08,"1"
  IF Keypad.BIT14 THEN  DEBUG CRSRXY, 06,08,"2"
  IF KeyPad.BIT13 THEN  DEBUG CRSRXY, 10,08,"3"
  IF Keypad.BIT12 THEN  DEBUG CRSRXY, 14,08,"A"
  IF KeyPad.BIT11 THEN  DEBUG CRSRXY, 02,10,"4"
  IF Keypad.BIT10 THEN  DEBUG CRSRXY, 06,10,"5"
  IF KeyPad.BIT9  THEN  DEBUG CRSRXY, 10,10,"6"
  IF Keypad.BIT8  THEN  DEBUG CRSRXY, 14,10,"B"
  IF KeyPad.BIT7  THEN  DEBUG CRSRXY, 02,12,"7"
  IF Keypad.BIT6  THEN  DEBUG CRSRXY, 06,12,"8"
  IF KeyPad.BIT5  THEN  DEBUG CRSRXY, 10,12,"9"
  IF Keypad.BIT4  THEN  DEBUG CRSRXY, 14,12,"C"
  IF KeyPad.BIT3  THEN  DEBUG CRSRXY, 02,14,"*"
  IF Keypad.BIT2  THEN  DEBUG CRSRXY, 06,14,"0"
  IF KeyPad.BIT1  THEN  DEBUG CRSRXY, 10,14,"#"
  IF Keypad.BIT0  THEN  DEBUG CRSRXY, 14,14,"D"
RETURN
    edited 2015-02-24 11:13
    What have you tried so far? What do you understand about what you need?
    Remember that your LCD expects characters, one byte per character, to be sent via SEROUT. Your keypad code supplies one bit for each button on the keypad and this is returned in "keypad" when you call ReadKeypad. There's no debouncing (look up debounce in the Wikipedia) done by ReadKeypad and there's no translation to a character. You have to do that yourself in your code. The NCD operator will take the "keypad" value and return the number of the first 1 bit found which you can use with LOOKUP to translate to a character. Look in the Stamp Reference Manual for the descriptions of these operators / statements.
    I think there's a Nuts & Volts column on using a similar keypad. Have a look at the code they use for suggestions. The archive is on Parallax's website.
  • CambodiaCambodia Posts: 2
    edited 2015-02-24 22:48
    We want it so that a user puts in a password and the microcontroller sees if it's correct (say the password is 1234) and if it is, the LCD will say "Authorized." and then reset after say 30 seconds.
    We've looked at the Manual for information on both keypad and passwords, and it has left us more confused than given us answers.
    The only Nuts&Volts column I see that might be the one you're referring to is #22, and we've already looked at it. I'll double check with it though.
    This is a code that we've been messing with to see if we could get it to work.
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    ' -----[ I/O Definitions ]-------------------------------------------------
    LCD    PIN 15  'lcd display
    ' -----[ Constants ]-------------------------------------------------------
    TxPin     CON   15
    n9600     CON   84
    ' -----[ Variables ]-------------------------------------------------------
    #IF _No_SPRAM #THEN
     buf  VAR  Byte(10)
    #ELSE
     chkChar VAR Byte
    #ENDIF
    tagNum   VAR Nib
    tkn      VAR Byte
    char     VAR Byte
    counter     VAR   Word                       ' Counter Variable
    Password    DATA  "1234"                     ' Store "secret" password here.
    index       VAR   Nib                        ' Index variable.
    userEntry   VAR   Byte(4)                    ' Store user entered password.
    ' -----[ EEPROM Data ]-----------------------------------------------------
    ' -----[ Initialization ]--------------------------------------------------
    ' -----[ Program Code ]----------------------------------------------------
    DO
    DEBUG "Enter password: "                                   ' User instructions
    SEROUT TxPin, n9600, ["DOOR LOCKED", 13] ' Print text, line feed
    DEBUGIN STR userEntry \4                                   ' Get user input password.
    FOR index = 0 TO 3                                         ' Check array against DATA
    READ Password + index, keypad                              ' Get next password char
    IF keypad <> userEntry(keypad) THEN EXIT                    ' Compare to user input,
    NEXT                                                       ' exit if not equal.
    IF index <> 4 THEN                                         ' If exit, then index not equal
    DEBUG CR,"Password not correct.", CR                       ' to 5 and pass is not correct.
      DO                                                       ' Alarm is ON
      SEROUT 2, 84, [22, 12] ' Initialize LCD
    PAUSE 500 ' 1/2 second delay
    ' Display evenly spaced characters on Line 0 every 200 ms.
    SEROUT TxPin, n9600, ["UNAUTHORIZED", 13] ' Print text, line feed
    SEROUT TxPin, n9600, [18]        ' Turn backlight off]
    PAUSE 3000
      LOOP
    ENDIF
    LOOP UNTIL index = 4                                        ' Only get out of loop when  ' index = 5.
    DEBUG "Authorized Unlocking Door", CR
    PAUSE 250
    DEBUG "Door Unlocked", CR
    FOR counter= 1 TO 59
    PULSOUT 14, 1000
    PAUSE 2
    NEXT
    SEROUT TxPin, n9600, ["AUTHORIZED", 13] ' Print text, line feed
    SEROUT 2, 84, [12]
    PAUSE 5000
    DEBUG  "Locking Door", CR, CR
    PAUSE 1000
    PULSOUT 14, 250
    PAUSE 2
    NEXT
    DEBUG "Door Locked", CR, CR
    END
    ' -----[ Subroutines ]-----------------------------------------------------
    ReadKeypad:
      keypad = 0
      DIRL   = %00000000
      FOR row = 0 TO 3
        DIRA = 1 << Row
        FOR column = 0 TO 3
        NEXT
      NEXT
    RETURN
    Update:
      DEBUG CRSRXY,0,7,
        "|   |   |   |   |",CR,
        "|   |   |   |   |",CR,
        "|   |   |   |   |",CR,
        "|   |   |   |   |",CR,
    RETURN
    Display:
    RETURN
    Which is based on this code:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    DO
      ENDIF                                     ' old display
        GOSUB display
      ENDIF
    LOOP
    ReadKeypad:
      keypad = 0
      OUTL   = 000000                        ' Initialize IO
      DIRL   = 000000
      FOR row = 0 TO 3
        DIRB = 11                            ' Set columns (P7-P4) as outputs
        OUTB = 00                            ' Pull columns low (act as pull down)
        DIRA = 1 << Row
        FOR column = 0 TO 3
        NEXT
      NEXT
    RETURN
    Update:
      DEBUG CRSRXY,9,15,
        "|   |   |   |   |",CR,
        "|   |   |   |   |",CR,
        "|   |   |   |   |",CR,
        "|   |   |   |   |",CR,
    RETURN
    Display:
    RETURN
    '-----[ PassCode Entry ]----------------------------------------------------------
    ' Entering passcode
    DO
      DO                                                       ' Alarm is ON
      FREQOUT 5, 500, 3000                                     ' Creation of a beeping sound
      HIGH 13                                                  ' Flashing LEDs
      LOW 12
      PAUSE 100
      HIGH 12
      LOW  13
      LOOP
    ENDIF
    DEBUG CR, "Password is correct;", CR,                       ' Program can move on when
                          "program can continue..."             ' password is correct.
    HIGH 13
       FOR counter = 1 TO 150                                   ' "Door Opens" (Sliding door)
       PULSOUT 14, 1200
       PAUSE 20
       NEXT                                                     ' Light ON for 5 sec
    PAUSE 5000
    LOW 13                                                      ' Then off
       FOR counter = 1 TO 150                                   ' "Door closes" (Sliding door)
       PULSOUT 14, 300
       PAUSE 20
       NEXT
    END
    We both don't have much knowledge with STAMP. Most of what we know about microcontrollers is from Ardunio and using C++
    edited 2015-02-25 07:15
    Unfortunately, you're trying to combine two pieces of code that were meant for different things and they don't combine as you've noticed. One scans a 4 x 4 keypad and returns 16 bits in a word, one bit for each key indicating which keys were pressed. The other handles organizing password input and display on an LCD, but expects input from the connected PC. There's a big piece missing that takes a 16 bit bitmap (for the keys), figures out when a key is pressed and released, and converts the bit for the pressed key into a character. For now I'd forget about the password handling and the LCD and work on this missing piece.
    ReadKeypad is good, but you don't need Update or Display or keypadOld. Have you looked at NCD and LOOKUP yet? You have to understand those.
    You need to create a subroutine (labelled GetAKey) that first sits in a loop (DO ... LOOP) calling ReadKeypad until keypad is zero. This ensures that none of the keys are pressed. Next in that subroutine is another loop (DO ... LOOP) that calls ReadKeypad until keypad is non-zero. This ensures that some key is pressed, maybe more than one. Now you have to identify which key is pressed and translate it like:
    keypad = (NCD keypad) - 1
    lookup keypad,["D","#","0","*","C","9","8","7","B","6","5","4","A","3","2","1"],keypad
    The result in keypad is the character code and your subroutine can RETURN with that in keypad.
    Go ahead and create the GetAKey subroutine. Read the Manual sections on DO/LOOP. Write a short main program (that comes first) that calls GetAKey and displays the result with DEBUG. See what you get.
  • GenetixGenetix Posts: 1,777
    edited 2015-02-26 12:52
    Cambodia,
    Mike Green has gotten you off to a great start!
    You should always have the Stamp Manual handy.
    http://www.parallax.com/sites/default/files/downloads/27218-Web-BASICStampManual-v2.2.pdf
    The older version of What's a Microcontroller had a password check program starting on page 289.
    https://www.pololu.com/file/0J204/What%27s_a_microcontroller_text.pdf
    Chapter 1 of the old Smart Sensors text shows how to use the Serial LCD.
    http://www.parallax.com/sites/default/files/downloads/28029-Smart-Sensors-Text-v1.0.pdf
    To modify ReusablePasswordChecker.bs2 you need to change all the DEBUG statements to SEROUT statements.
    Adding CR CON 13 to the Constants section of your program will take care of any CR that is part of a DEBUG statement since a CR is actually an ASCII code of 13.
    Also, if you notice some of your SEROUT statements end in 13 which is the same as sending a CR, so you can change them to CR since that's what they mean.
    The password entry and check code is more of a problem since DEBUGIN will read in a String of 5 characters.
    You can either call Get-A-Key 5X and store each value in a String BEFORE the FOR..NEXT or call Get_A_Key before the READ statement in the FOR...NEXT loop.
    Remember though that normally a person will see the display change as each key is pressed. You can either display the key that was pressed or * so no one else can see it. To do this you would first call Get_A_Key and then send a SEROUT to the LCD.
    Here's a post where I showed an easy way to read a numeric value using the keypad. http://forums.parallax.com/showthread.php/156472-programming-the-basic-stamp-with-keypad-to-be-able-to-read-and-write-00-99?p=1286903&viewfull=1#post1286903
    You can use the keyscan subroutine portion of this along with the attached code to see how this kind of stuff is done. The attached program is from a demo I did back in 2006 using an EDE1144 keypad decoder. But between the two programs there is a lot of useful information there. Hopefully you will find it useful.
    The Security test code even has a timeout function on the input as well as the ability to support extra functions from the keypad.
