Prop to Python troubles
AGCB
I'm just learning to use Python in some very simple programs. I have gotten Arduino to talk to the Python program, but can't seem to figure how to get Prop to do the same.
I've been trying to use the Full Duplex Serial object. (or FDS Plus, have also tried PST) Maybe I'm wrong on this.
Here is the simple Python program
And here is the Arduino program that works
And here is the prop program that doesn't work
I know it looks like baud rates are different (they are for the Arduino and prop programs) but they are right (matched) when I use them. The com port is also matched for each program.
So my ? is, am I using the FDS right or is there something better or easier? I get no errors but no output from the Python when using the Prop
Aaron
import serial
PropData = serial.Serial('com4',115200)
while (True):
if (PropData.inWaiting()>0):
myData = PropData.readline()
print myData
int cnt=0;
void setup() {
Serial.begin(9600);
void loop() {
Serial.print("I am counting to: ");
Serial.print(cnt);
Serial.println(" Mississippi.");
cnt= cnt+1;
delay(1000);
CON
_clkmode = xtal1 + pll16x '80 MHz system clock
_xinfreq = 5_000_000
OBJ
fds : "fullduplexserialplus"
'fds : "parallax serial terminal"
VAR
byte num
PUB main
fds.start(31,30,0,115200)
repeat
fds.dec(num)
fds.str(string(" one-thousand "))
waitcnt(clkfreq+cnt)
num++
Aaron
Try fds.str(string(" one-thousand ",$0d,$0a))
AAron
