Open Source ZigBee
Greetings everyone!
I need a zigbee module, which accepts an external antenna( w/ u.fl or rpsma connector, or even better sma-male)
I say even better, because on the antenna i am going to use sma launcher and not u.fl launcher (as i know, it doesn't exist).
Moreover, theres NO problem if this module is a shield or intergrated in an MSU.
With a little searching i found a few msu's that provide this.
More important, is that i need this module to be open source, in order to modify its routing table.
If you have any ideas about that, i would really appreciate it.
