Something is WRONG with SimpleIDE — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2015-02-14 16:47 in Propeller 1
After my updates were hanging, I decided to uninstall SimpleIDE and try a fresh install. After doing the uninstall, I opened Windows exploxer, only to find that the SimpleIDE folder still existed and so I attempted to send it to the recycle bin. The attempt to delete failed because the name was too long and so I began to investigate. No matter what I try, all attempts fail.
EDIT: It is probably a good thing I was at my computer and terminated the SimpleIDE process, otherwise... who knows how large that directory tree may have grown :)
568 x 682 - 40K
366 x 455 - 30K
  • ValeTValeT Posts: 308
    edited 2015-02-14 10:23
    idbruce wrote: »
    Holy cow!
    That is weird. I am having no problems with my numerous installs of SimpleIDE. What version are/were you running?
    If you install a fresh copy of SimpleIDE, can it remove the directories automatically? I would try that first......
    Good luck,
    ValeT
    edited 2015-02-14 10:27
    Honestly that looks like a Virus .... The tactic is to create a never ending chain of recursive directories eventually disabling the FAT (File Allocation Table)
    edited 2015-02-14 10:31
    That sounds more likely compared to an issue with SimpleIDE. Do you have any idea how to fix this ( I would like to know too just in case I get infected :) )? Is there any way to manually force the computer to remove the directories ( such as can you rewrite the memory sectors the files are located in )?
    ValeT
    edited 2015-02-14 10:42
    "Do you have any idea how to fix this" - No idea other than a re-format and everybody loves doing that. The last time I saw something like that with the re-cursive directories was in the mid-90's and maybe once or twice there after....... I think what I was able to do was to rename the "Parent" directory as something else, but I could not delete it... but to rename it I used a HEX editor to directly manipulate the FAT name. That was only after I ran whatever available virus scan I could find at the time. It remained that way until I decided to re-format and start fresh with a clean system.
    edited 2015-02-14 10:45
    Uh, that doesn't sound good.
    When in doubt, you just got to reinstall :) ...........
  • ElectrodudeElectrodude Posts: 1,687
    edited 2015-02-14 11:13
    If it's actually a corrupt filesystem, shouldn't a file system check find it?
    NTFS does allow things like that - I think they're called junctions. They're similar to soft and hard links on Unix.
  • dnalordnalor Posts: 223
    edited 2015-02-14 11:17
    Which windows you have? Windows 7?
    Try to start windows-explorer as administrator (right-click, select run as administrator or something like that).
    Delete the flag "read only" in the attritbutes (see your second picture). Then try to delete.
    If that not helps, I don't know.
  • idbruceidbruce Posts: 6,197
    edited 2015-02-14 11:54
    I finally got the directories deleted after a little luck with some rename and move......
    I believe the version was 1.0.2
    Having worked with Windows pretty extensively in the past, I do not believe it is a virus. I believe the problem began to occur, when I decided not to accept the default workspace in My Documents, during the install, and I provided another path to my Desktop. From that point forward, I believe the update software became corrupt.
    EDIT: OS = WINXP SP3
    edited 2015-02-14 16:28
    Jazzed
    Did you ever install a version of SimpleIDE before?
    Yes, I did have an earlier version installed at one time, which I uninstalled, however at that point, I never did check whether the the uninstall had completely removed all items from Explorer.
    What exactly did you do before you noticed this?
    I did a CTRL + ALT + DEL during an upgrade, due to what seemed to be an endless loop. And I should say, that I did this on more than one occassion.
    Was it simply by installing the workspace to a folder other than "Documents" ?
    I believe this was the culprit. If I had to guess, I would guess that there is a conditon of whether that My Document path exists, if not, then create directories, and perhaps in combination with, if no success then try again.
    I have not checked the registry, but are you saving the path of that dialog to the registry and basing update locations off that path?
    Jazzed
    Additionally, although I am not 100% certain, I believe this is the path that I used during the that install:
    C:\Documents and Settings\Bruce\Desktop\SimpleIDE\
    On the following install, I accepted the default :)
