i2c LCD display
Hello All:
Has anyone tried the i2c LCD displays? Or have a spec. sheet for them?
I have tried every i2c/SPI set up that I can think of and not a single pixel?
The unit I have has
GND 'ground
VCC 'power
SDA 'data
SCL 'clock
The display has a part# J204A on the back, (Main LCD Board) And hosts a chip,(small standoff board) with these numbers PCF8574T , T65941, ktM98483, Thailand
Thanks in advance for any help with this!!!
The unit I have has
GND 'ground
VCC 'power
SDA 'data
SCL 'clock
http://electronics.stackexchange.com/questions/101721/controlling-an-lcd-device-using-serial-i2c-module
You will have to determine how the PCF8574T ( which is an I2C Port expander ) is connected to the display. Then you are going to have to bit-bang the display commands in 4-bit mode.
Google J204A and you may find additional information.
Hal
Thanks Hal Albach...The site looks promising.
It's way beyond this thread to explain how Google works when you have searched and searched.
Many thanks JonnyMac
That's were I got mine from. $8.00 4x20
