FYI re Propeller Project Board — Parallax Forums
kwinnkwinn Posts: 8,697
edited 2015-02-24 06:55 in General Discussion
This board is not on the Microcontrollers >> Propeller >> Boards page. Should it not be there for all to see?
  • Courtney JacobsCourtney Jacobs Posts: 903
    edited 2015-02-17 08:46
    When it is brought back into normal stock it will once again appear in that section of the catalog.
  • Hal AlbachHal Albach Posts: 747
    edited 2015-02-17 10:59
    kwinn: This board is not on the Microcontrollers >> Propeller >> Boards page. Should it not be there for all to see?
    This is a phone in sale only for Forum members. ( I just ordered 5)
    Hal
    edited 2015-02-17 11:17
    The $8.99 Project Board selling through phone-in sale only has been given a different stock code (910-32810A) to keep the discounted boards containing the defect (Rev C) from mixing with the upcoming Rev D stock.
    I believe kwinn was asking why the store product had an active page but was not browseable through the catalog. This is mostly due to our ornery inventory software; don't worry, once Rev D boards are available everything should appear as normal on our website.
    edited 2015-02-21 12:46
    Exactly so Courtney. I was actually looking for the schematics to download and was surprised to see that the board was not listed. That ornery inventory software needs to be beaten into submission so it shows all the products that are carried even if they are out of stock otherwise customers might think they are no longer available.
    edited 2015-02-21 15:51
    I usually search by product name, in this case "Project Board". and it brings up this page:
    http://www.parallax.com/search?search_api_views_fulltext=Project+Board
    edited 2015-02-22 19:44
    Publison wrote: »
    That's what I did after not finding it on the Microcontrollers >> Propeller >> Boards page. Of course I knew there was such a board since I have used it before. The purpose of the post was to point out that someone new to Parallax might not see it if it is not listed where one would expect it to be.
    Wow, post 5,555. Have to find a project that needs five 555 timers tomorrow.
    edited 2015-02-23 13:47
    Finding this product should be easy now. It's back!
    http://www.parallax.com/product/32810
    edited 2015-02-23 13:50
    Yippee!!!!
  • WhitWhit Posts: 4,191
    edited 2015-02-23 17:43
    Good news! What a great product.
  • RsadeikaRsadeika Posts: 3,873
    edited 2015-02-24 05:44
    Am I going blind? I see the 3.3V access, but I do not see a 5.0V access.
    Ray
    edited 2015-02-24 06:27
    Rsadeika wrote: »
    Ray
    There has never been 5.0 volt on the Project Board. It just has a 3.3 Volt Regulator.
    There is a spot on the back for a LDO Regulator that could be any value, probably up to 12 volt with 16 VDC input.
    edited 2015-02-24 06:38
    Unlike the Activity Board the Project Board does not provide access to the USB 5 Volt input. You must supply 5 - 16 Volts to the board which become Vin and a 5 Volt LDO regulator and solder it to back of the board next to where you provide Vin. 5 Volts then becomes available from the 8-Pin Bridge just below Vin. When using the LDO regulator Vin obviously must be greater than 5 Volts. You can also just provide 5 Volts to Vin in which case the Vin bus at the bottom will be your 5 Volt bus.
    Hal Albach wrote: »
    Very good point Hal!
