Text barely readable.
I have been working on the Prop BOE tutorial and the code pane is barely readable. The text is run together. What do I need to do to fix this?
Thanks in advance.
Prop Tool.pdf
Thanks in advance.
Prop Tool.pdf
pdf
83K
That sure looks strange. I've never seen something like that with the Prop Tool myself.
I suppose you've tried the usual and done a shutdown and restart? It kind of looks like the font isn't being handled correctly.
You could try Propeller IDE or BST.
Go to :
C:\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Help\Content\Resources\Stylesheets
C:\Program Files\Parallax Inc\Propeller Tool v1.3.2\Help\Content\Resources\Stylesheets on a 32-Bit machine
and double click the Parallax font, and select install.
What OS are you running?
I see Publison recommended several things. Which one worked?
It's good to hear you got the problem fixed.
Going to C:\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Help\Content\Resources\Stylesheets. And do the install.
My OS is Vista SP2. 32 bit machine.
Thanks again.
