DS1820 with jm_ds1820_demo.spin only responds "no device" — Parallax Forums
StefanL38StefanL38 Posts: 2,292
edited 2015-02-11 17:49 in Propeller 1
I'm trying to use Jonny Macs DS1820-Democode on my Propeller-Professional-Demo-Board (PPDB)
The only respond I get on serial terminal is "no device"
I tried the schematic provided in the democode
I have 10 sensors in a TO-92 package. Frontview GND DQ Vdd
DQ to Prop-Pin prop-pin has a 5k7-pullup-resistor
Vdd connected to +5V
I also tried the variant Vdd connected to GND (parasitic power-supply mode)
I also tried the variant Vdd connected to +3.3V
Then I changed the sensor.
Always the same result: demo-code responds "no device"
Now I'm pretty stumped what else I could do.
The code that is printed onto the sensors is "DALLAS DS1820"
Does anybody know of any trap I stepped in or any trick to make it work?
    edited 2015-02-11 15:00
    OK I got it.
    It was something you can't see from more than 1m distance off my PPDB.
    Using a 5.7 Ohm-resistor as pullup is a pretty-low resistance.
    This resulted in a voltagedrop of only 0.3V which is not enough to get the bitbanging going
    Now with a 4k3 resistor the sensor responds as expected
    best regards
    Stefan
  • MJBMJB Posts: 1,235
    edited 2015-02-11 15:27
    StefanL38 wrote: »
    the DS18B20 has 12 bits of resolution instead of the only 9 bits the old DS1820 has.
  • JonnyMacJonnyMac Posts: 9,834
    You have to be very careful with 1-Wire devices. Personally, I always use a 3.3K pull-up to ensure that I get clean signals the line.
