wrword error question — Parallax Forums
David BDavid B Posts: 593
edited 2015-02-06 07:26 in Propeller 1
What's illegal about using a word variable for wrword when writing to a word hub address?
If the commented line is uncommented, the propeller tool says "Error: Address is not long." Otherwise the code works as expected.
DAT
org 0
test_cog
        mov     data_pointer, par
        wrword  a_long_1, data_pointer
        add     data_pointer, #2
        wrword  a_long_2, data_pointer
        wrword  a_word_1, data_pointer
    '    wrword  a_word_2, data_pointer  ' <- compiler says "Error: Address is not long."
idle    jmp     #idle
a_long_1        long 1
a_long_2        long 2
a_word_1        word 3
a_word_2        word 4
data_pointer    res 1
    edited 2015-02-05 15:42
    Words don't actually exist in cog RAM, since cog addresses increment by one for each long. So there's no way in a cog to reference a cog word that's not long aligned in the hub. To write a_word_2 to the hub, do it this way:
            mov      temp,a_word_1
            shr      temp,#16
            wrword   temp,data_pointer
    ... or, if you don't want to use a temporary variable:
            ror     a_word_1,#16
            wrword  a_word_1,data_pointer
            ror     a_word_1,#16
  • ozpropdevozpropdev Posts: 2,793
    Only LONG directives can be used within PASM code.
  • David BDavid B Posts: 593
    edited 2015-02-05 15:58
    Thanks. I can make the variables longs and get the asm to work, but it seemed like it would have been more consistent to use word variables in places where the data will only be words. It seemed kind of odd that they are allowed to be declared but are not allowed to be used.
    edited 2015-02-05 16:13
    They are allowed to be used as word variables ... in the hub, but not in the cog. Since cog addresses are nine bits long, there are only 512 discrete locations possible there. If the cog addressing granualrity were word-sized instead of long-sized, cog RAM would be half as long as it is now. If the granuarity were byte-sized, a quarter of what it is now. So I think the current design is the correct one.
  • RaymanRayman Posts: 16,223
    edited 2015-02-05 16:41
    I think life is a whole lot easier if you only use longs in your assembly code...
    Unless you have a large table in bytes or words, it's probably not worth the trouble...
    edited 2015-02-05 17:35
    If you have a table of bytes or words -- no matter what the size -- it's easier in PASM to access them from the hub.
  • ElectrodudeElectrodude Posts: 1,686
    edited 2015-02-05 18:37
    It's usually faster, too, except with worst-case hub timing, and it definitely uses less cogram.
    hubram:
    mov tmp, baseptr ' 4 ticks
    mov tmp, offset  ' 4 ticks
    rdbyte tmp, tmp  ' 7..22 ticks
              ' total 15..30 ticks
    cogram:
    {mostly stolen from Spin Interpreter}
    ror tmp, #2      ' 4 ticks
    add tmp, baseptr ' 4 ticks
    movs $+2, tmp    ' 4 ticks
    shr tmp, #27     ' 4 ticks
    mov tmp, 0-0     ' 4 ticks
    shr tmp, offset  ' 4 ticks
    and tmp, #$FF    ' 4 ticks
              ' total 28 ticks
    edited 2015-02-05 23:13
    I have a 16 bit ADC running from one cog, writing to a long location in the hub, with a application in another cog reading the values from the single long hub location on a timed basis.
    But I wanted to convert it to have the adc write to a several K sized hub array as a circular buffer where since it only uses 16 bits, writing longs would be really wasteful of ram.
    It looks like it's working now; it was just that word declaration thing that caught me by surprise.
  • tonyp12tonyp12 Posts: 1,951
    If you want speed and no shifting in cog, temporary store all 16bit data in the cog as 32bit long, the upper 16bits could be used for something else if you need flags etc.
    Every time you want to send the lower 16bit of those longs, you do this below and you will not waste any HUB ram
    Though I see that hub access will stall as 2 (regular) cog instructions in between is fastest, so optional put 2 more instruction in the loop that does something useful.
            mov   hubaddrs, PAR
            movd  loop,     #cogbuffer   ' restore table pointer
            mov   buffcnt,  #16
    loop    wrword 0-0,     hubaddrs
            add   loop,     _bit9
            add   hubaddrs, #2
            djnz  buffcnt,  #loop
    _bit9     long |<9
    hubaddrs  res 1
    buffcnt   res 1
    cogbuffer res 16
