Spin demo code for the TSL235? — Parallax Forums
vanmunchvanmunch Posts: 568
edited 2015-02-05 10:43 in Accessories
Hey everyone, I'm evaluation some different color sensors and I would like to try a TSL235 (?R?), but I haven't been able to find any Spin code for it. http://www.parallax.com/product/604-00084 There is an example for using an Arduino from Parallax, but nothing for the Propeller chip. I think the world is upside down....
http://learn.parallax.com/tsl235r-light-frequency-converter-arduino-demo
I've also checked the Obex and no luck, does anyone have a simple demo that they would be willing to share?
Thanks for your time,
Dave
  • vanmunchvanmunch Posts: 568
    edited 2015-02-04 14:55
  • JonnyMacJonnyMac Posts: 9,850
    edited 2015-02-04 16:58
    There are many more ways to "skin the cat" as it were when using the Propeller. Do you want to read the frequency periodically, or would you like to devote a cog so that you have constant updates? If the latter, how often? Is once per second enough?
    edited 2015-02-04 17:41
    JonnyMac wrote: »
    Hey JonnyMac,
    Thanks for asking.
    The goal is to find the best method and sensor(s) for detecting (individually) red, green, blue, IR, & UV light reflected from an object about 2-3 inches away.
    I've currently been testing a number of different sensors (photo-resistors, photo-resistor diodes, TSL235, etc.) In the end I'll create an array of 5-12 covering an area about 8 inches wide. The refresh rate will need to be at least 10 hz. I had been planning on dedicating a cog for this job.
    BTW I always enjoy reading your articles in N&V.
    Dave
    edited 2015-02-04 17:51
    I don't have one of those sensors, but I do know how to program the Propeller. I did a direct port of the Arduino demo in just a few minutes. I set the loop time to 10ms so that the output would be an even fraction (1/100) of the input frequency. Since I don't have one of those sensors I used the Synth object to create a test frequency.
    var
      long oldcount
      long temp
      long avg
      long freq
      long loopcount
    pub main | t
      setup
      t := cnt
      repeat
        waitcnt(t += (10 * MS_001))
        temp := phsa                                                 ' capture current count
        freq := temp - oldcount
        avg := avg + freq
        if (++loopcount == 25)
          term.tx(CR)
          term.dec(avg / 25)
          term.tx(CLREOL)
          avg := 0
          loopcount := 0
        oldcount := temp
    pub setup
    '' Setup IO and objects for application
      term.start(RX1, TX1, %0000, 115_200)                           ' start serial for terminal
      ctra := (%01010 << 26) | TSL                                   ' setup pin to count positive edges
      frqa := 1
      ' for testing only -- remove this line when sensor is connected
      synth.synth("B", TSL, 300_000)
    The key to my code is using a counter in POSEDGE mode -- this mimics the edge-triggered interrupt of the Arduino. You can easily drop this code into a Spin cog to provide a count/period to your foreground application.
    edited 2015-02-04 18:10
    Here's how easy it is to monitor the sensor in the background, getting an update every 100ms (10Hz) -- as you would expect, the result is the input frequency frpm the TSL235 / 10.
    var
      long  cycles
    pub main | t
      setup
      t := cnt
      repeat
        term.tx(HOME)
        term.dec(cycles)
        term.tx(CLREOL)
    pub setup
      cognew(run_tsl235(TSL, @cycles, 100), @tslstack)               ' start TLS monitor cog
    con
      {  T S L 2 3 5   M O N I T O R  }
    var
      long  tslstack[32]
    pri run_tsl235(pin, p_result, ms) | new, old, t
    '' Monitor TSL235
    '' -- updates long at p_result every ms milliseconds
      ms *= clkfreq / 1000                                           ' convert ms to ticks
      new := 0
      old := 0
      ctra := (%01010 << 26) | pin                                   ' setup pin to count positive edges
      frqa := 1
      phsa := 0
      t := cnt                                                       ' sync with system timer
      repeat                                                         ' loop forever
        waitcnt(t += ms)                                             ' wait ms milliseconds
        new := phsa                                                  ' capture current count
        long[p_result] := new - old                                  ' report count to foreground
        old := new                                                   ' save for next cycle
    Are you also considering integrated RGB color sensors, such as the TCS3472, TCS3490 or ISL29125? Those use the i2c interface.
