Suddenly a Spate of Smallish Steppers
http://www.ebay.com/itm/10pcs-6MM-Miniature-stepper-motor-with-copper-gear-Digital-camera-stepper-motor/161292626033
http://www.ebay.com/itm/10pcs-DC-Micro-Digital-Camera-Stepper-Motor-6x5-5mm-with-Copper-Gear/181409446330
http://www.ebay.com/itm/10pcs-3-5V-DC-4-wire-2-phase-Micro-stepper-motor-Mini-motor-dia-10mm-with-gear/251775459175
http://www.ebay.com/itm/10PCS-2-Phase4-Wire-micro-stepper-motor-mini-DC-stepping-motor-With-small-screw/251723001832
http://www.ebay.com/itm/5PCS-DC-Mini-motor-Micro-stepper-motor-7MM-stepper-motor-with-division-bar/171334138763
http://www.ebay.com/itm/50pcs-3-5V-dc-10-kinds-of-4-Wire-2-Phase-micro-stepper-motor-Mini-stepping-motor/251773294490 50 pc variety pack for $19
Who will answer the call?
I never told you about it, but I while back, I created a small bot from a ProtoBoard and a couple floppy drive steppers. It was pretty cool but the steering was not accurate enough to make me happy. I was all eager to take some photos and a video, but when I seen the poor steering, I gave up on that idea. The problem with those auctions are that they do not specify a step angle. For steering a small bot, I would want a step angle of 1.8. For a drive motor, larger step angles could be utilized, and would probably be more beneficial.
Bruce
So far they've been 'a solution waiting for a problem'...
The only thing I can imagine using them for right now is to put them inside a plastic aeroplane model, and make the prop spin, the flaps and rudders move. That kind of stuff. It's on the ever-growing project list...
Altoids tins arent all the good for a CnC, though. Not enough Z-axis travel.
Instead, try building it out of NanoBeams.
http://www.nanobeam.us
(I just got a 16pack of them... They're ridicilously tiny)
They ran out but I got some small DC motors with tiny nylon harmonic planetary gearbox from them -
50rpm in one step is awsome for a tiny robot... Like hens' teeth I now realize, wish I'd bought loads now.
Still I'll keep looking..
e.g. http://www.ebay.com/itm/10pcs-With-screw-2-phase-4-wire-stepper-motor-Canon-6mm-micro-stepper-motor-/171588328169
(I expect it to be no more than 16)
They'll need a lot of gearing anyway to move anything, so there'll be plenty of steps anyway.
Just think, some of these steppers are small enough to fit inside a pen! (or an arrow shaft... )
Add a microcontroller (I have some LPLC TOO https://www.kickstarter.com/projects/301993907/lplc-too-internet-of-things-microprocessor ) and batteries (BR425 Lithium cells)
There must be some possibilities there...
I had thought about powering the coils directly from a Prop's I/O pin and seeing how long the Prop would last.
Maybe I could glue some pennies to the gears to act as wheels?
