Boe-Bot Navigation Question
Hi all,
I have 2 questions related to Boe Bot Board of Education with Arduino.
1. Has anybody taught the curriculum available at learn.parallax for this robot? How long would approx take for a HS class that meets daily to complete chapters 1- 4? How about chapter 5?
2. The other question refers to the way Boe Bot moves. Why does one wheel need to rotate clockwise( right) and the other counterclockwise( left) to move forward? It seems odd to me, wouldn't be easier to move both wheels, forward, backward, etc? ( Lego has this, if I'm not mistaken) Is this similar to how the wheels turn in real world?
The motors on the BOE-Bot are continuous rotation (CR) servos. The user doesn't have access to the actual h-bridge inside the servo. With a h-bridge, one can just swap the power lines to the motors to reverse its direction. With a CR servo there's not an easy way to make one reversed (though it is possible). Since you don't have the option of reversing the direction of the motor with the wiring, you have to have the motor spin in the opposite direction by sending the appropriate pulses.
Sorry, I can't help with the first question.
I taught a bunch of middle school students, and it took us the whole year to complete the kit including all of the projects. We met once a week for 1.25 hours.
Hope this helps,
ValeT
Only if the motors were mounted to the chassis is the exact same way. But they're not. They're mounted opposite one another, like in a mirror. So, to go forward, one motor must turn in a mirror image to the other.
You're thinking motors like this, where you can mount the wheel on either side of the axle:
https://www.pololu.com/product/67
