PIR Sensor not going to ground
Well, I know there are threads with PIR in the title, but, search wouldn't find them. So, I will just post.
I recently got a PIR 28027 Rev. B. It operates with no load. However as soon as I hook it up to a 74LS14 Inverter, it won't go to 0V. So the output of the inverter stays low.
The chip is good and it doesn't matter which input I put it on, the same thing happens.
It goes high when motion is detected. When it turns off, it drops to about 1.2V. In my usage, this isn't enough to set the output of the inverter high.
If I disconnect it from the inverter, it goes on down to 0V. The documentation is useless. It doesn't specify whether it's supposed to have a pull down (I would assume not.) I'm powering it with +5V. The test circuit is the PIR and the 74LS14, no other loads of any kind.
Now, before, I was using a 74LS00 NAND, with one gate rigged as an inverter and it worked fine. For the halibut, I put a 1K pull down on the LS14 and it pulled the signal down to about 1V. I also tried another LS14 chip and it did the same thing.
Any ideas (like I'm missing some fundamental rule on using the LS14?)
Can you take (and post) a photo of your setup?
[why do I get the feeling I'm going to feel stupid real soon?]
A "fix" might be to use a 2K to 5K pull-down on the output-- or return for another unit.
It looks like I need to do some studying of all this to educate myself on what is truly required to operate these chips. I was under the mistaken impression that a TTL input was a TTL input. ... or mistaken about how the PIR would/should have no problem with a standard TTL input. or maybe I'm still in the stone age and should think latest technology (the chips I'm using are literally 30+ years old ... I know 'cause that's how long they've been in my kit since school .... and please don't go there .... whatever you're thinking.)
So thanks to all who responded. Just talking to others helps break out of that box you get into when you stare at a problem too long. I'm smarter for it.
[ this explains it .... I went to school, worked at it, changed careers, and 20 some years later I am returning to electronics. So I've forgotten everything I knew about it and am relearning it.... of course, then, I'll have to start learning all the new stuff that's been developed since then ... sheesh ..]
I'm thinking when the DVM was connected between ground and the output it acted as a 10meg or 100meg pull down resistor. A scope probe would do the same thing. This gave the appearance the PIR worked and the 74LS was the problem. Bottom line is the circuit needs a pull down to be reliable.
I think you're right about the low drive transistor being toast. If the output pin touched +5V even briefly while the PIR was not detecting, the short circuit current through the output would probably blow that transistor. At least there's a work around with the pull-down resistor.
