Freq generation
I need to generate 2 separate freq but they must be output on single pin and use only 1 cog. I need to generate a 123.50 Hz and a 82.41 Hz signal at the same time and mixed, to be output on P10.
I was looking at the OBEX " http://obex.parallax.com/object/244" file of Frequency Synthesis/PWM X8 but not sure if it can do what I need.
Thank you
Thank you
Hope this helps, not really familiar with tone gen on the propeller, onlt digital signals.
Thank you
Phil Pilgrim (PhiPi) , thank you.
