Questions for S900 building
Hello everyone= Hope I can find some help!
New to multirotors, even though I learnt to fly with an aircraft lended by a friend of mine, I am starting a building for professional use and photoshooting.
Here's the setup:
DJI S900
ZenMuseGH4
IOSDMk2
DJI A2
The radio is a Futaba T14SG.
For the battery, I own a 6s LIPO 12 000 Mah battery and I'd like to know if it could work to fly during 15 minutes, but I'm not quite sure?
Plus, for safety, I thought of equipping the aircraft with a rescue kit, as the DJI dropsafe or the rescue kit for DJI S900 from Opale Paramodels, that seems interesting. Anyone heard about these products? or using them maybe? It's a little pricey but considering the cost of the total setup, it could worth the value on the long-term, for the aircraft itself, people, animals, houses that could be damaged...if there are users of rescue systems, i'd like to hear from you= Thank you very much
Greetings
Here's the setup:
DJI S900
ZenMuseGH4
IOSDMk2
DJI A2
Greetings
As for safety, not sure where you're located. Maybe its better to check with your local authorities if there are any regulations on this?
Update us with images once you have your rescue mach setup!
Jackie.
A little late with the reply
