100 Caps for a Buck
OK, $1.25 but they are electrolytics! At 1.25 cents each, who would even bother faking that many?
100x 10uF, 25VDC. I'll use them for 5VDC filter caps, so even if they are seconds and the ratings are off 50%, who cares?
http://www.ebay.com/itm/171610924827
Beware of cheap electrolytic caps.
Years ago the formula for the electrolyte used in electrolytic caps was stolen.
But, the thief only got 1/2 the formula.
Many Asian companies used the stolen formula to make capacitors, but their capacitors would fail prematurely.
The bad capacitors found their way into all kinds of name brand consumer electronics, such as PC's, TV's and Monitors.
http://whatreallyhappened.com/WRHARTICLES/badcaps.html
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net/
Premature ageing and failure is the problem and I'd rather spend 10 cents on this cap and make sure. I know this goes against the erco grain, spending 9 cents more when 1 will do
BTW, @Zappman, interesting read on the cap plague which is something I've always been aware of but didn't know it was "official". I've had so many PVRs and monitors etc fail fail fail because of this and some I even bothered to repair. Even $exchange$ ECMs have been good business for some who only have to replace an electrolytic on the faulty units then recycle them back as $exchange$ ECMs!
The operating conditions directly affect the life of an aluminum electolytic capacitor. The ambient temperature has the largest effect on life. The relationship between life and temperature follows a chemical reaction formula called Arrhenius' Law of Chemical Activity. The law put simply says that life of a capacitor doubles for every 10 degree Celsius decrease in temperature.
So even if the caps in this offer are filled with a wonky electrolyte, I'll bet they'll work great attached to an LD1117 and sitting in a 20C office. But I also heard a few months ago that Chinese manufacturers were purchasing electrolyte from Japan. So these may not be wonky. Either way, seems pretty interesting to me.
It goes without saying that no one should be decoupling their core i7 with these.
http://www.ebay.com/itm/1000-X-Panasonic-ECE-V1EA330SP-CAP-33UF-20-25V-AL-CASE-D-SMD-/230740699092?pt=LH_DefaultDomain_0&hash=item35b937a7d4
$6.50 for 1000 instead of $1.25 for 100...
(Well, shipping sucks on the Panasonics, the no-named doesn't ship to Norway. Guess which I bought... )
These Panasonics have long leads, so they can be straightened and even used on breadboard or thru-hole designs.
Ironically, I live just a few miles away from the seller... but no local pickup. Ah well.
Walter
http://www.mouser.com/ProductDetail/Nichicon/UPW1C100MDD/?qs=sGAEpiMZZMtZ1n0r9vR22UwyiKSDS%252bfFV%2f%252bROJNL1dU%3d
If you only need 10uF 16V:
4cents for Ceramic 1K order
http://www.mouser.com/ProductDetail/Murata-Electronics/GRM21BC81C106KE15L/?qs=sGAEpiMZZMs0AnBnWHyRQKFZIQ7b73cdGHxNihrk%2fykL%2fs1exAwMsg%3d%3d
11cents for Tantalum at 1K order
http://www.mouser.com/ProductDetail/AVX/F931C106KAA/?qs=sGAEpiMZZMsh%252b1woXyUXjx8BsXRNKjx1adrZjqUlTRY%3d
I would rather double up on Ceramic until I need to be above 50uF, then go Tantalum until I need to be above 400uF
They are rated at specified amount of time only at top working temperature. For the lower temperature, there is no such rating. I've seen electrolyes made 50-60 years ago, that still run OK.
For the actual runtime for specific capacitor in specific conditions, Cornel Doubilier has very nice calculator on their website.
Dang it, now I have a bunch of those too. 1900 to be precise. I bought a batch of 1000 for $5.50 (best offer) then the seller emailed that he had 900 left and would I want them for $4.50. Tempting a hoarder...
So what's a fellow to do with 2000 capacitors? Build some sort of analog RC computer? Filter the Smile out of every project from now on?
Duane Degn will inherit these when I die. Buried under an avalanche of capacitors in a minor earthquake.
That started out as a joke, but it's actually not a bad idea.
They would be handy for making buck converter's LOL
I usually test caps before I use them and once in a while I find a bad one. Physically they look great , new etc.
