Unable to access high side of 24lc512 on my PPD — Parallax Forums
tj4sheetj4shee Posts: 25
edited 2015-01-20 18:30 in Propeller 1
Hi, was hoping someone could offer some suggestions or reasons on what I am doing wrong.....
I have a Parallax Prof. Dev. Board.. and I replaced the 24lc256 eeprom with a new 24lc512.... with the hopes of using the space at $8000 and above....
But I can't seem to get to it via the typical eeput routines.... the commands do nothing.... verified via Tachyon Forth and dumping the area I was trying to write to.
I know the chip is good... I can read and write to $8000 using Tachyon Forth..... and I am able to load and run programs from the bottom half of the chip.... i.e.... thats where I load and run Tachyon....
So any suggestions on what I fail to know or do ?
Thanks, TJ
    edited 2015-01-20 17:27
    tj4shee wrote: »
    Thanks, TJ
    So in TF you should be able to do EC!, EW!, and E! to write bytes, words, and longs. Then dump out the EEPROM to verify it has written.
    $12345678 $F800 E! ok
    $F800 $20 EE DUMP
    0000_F800: 78 56 34 12 FF FF FF FF FF FF FF FF FF FF FF FF xV4.............
    0000_F810: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ok
    But this begs the question, what do you mean by "the typical eeput routine"? Isn't that something you should be elaborating on?
  • tj4sheetj4shee Posts: 25
    edited 2015-01-20 17:47
    $F800 $20 EE DUMP
    correct....
    sorry, didn't specify I was using SimpleIDE and C.... for which Simpletools.h has a set of commands to write to the eeprom..... so this code does not write to the eeprom....
      EEPROM Data.c
      Write values and text to the Proepller Chip's dedicated EEPROM, and then
      read back and display.
      http://learn.parallax.com/propeller-c-tutorials
    #include "simpletext.h"
    #include "simpletools.h"                      // Include simpletools header    .
    int main(void)                                // main function
        ee_config(28, 29, 0);
        int addr = 32769;                           // Pick EEPROM base address.
        ee_putInt(42, addr);                        // 42 -> EEPROM address 32769
        int eeVal = ee_getInt(addr);                // EEPROM address 32769 -> eeVal
        print("myVal = %d\n", eeVal);               // Display result
        ee_putStr("hello!\n", 8, addr + 4);         // hello!\n -> EEPROM 32773..32780
        char s[8];                                  // Character array to hold string
        ee_getStr(s, 8, addr + 4);                  // EEPROM 32773..32780 -> s[0]..s[7]
        print("s = %s", s);                         // Display s array
    TJ
  • JonnyMacJonnyMac Posts: 9,649
    edited 2015-01-20 17:49
    The PPDB doesn't have a pull-up on the EEPROM SCLK line -- this may be causing the problem.
    edited 2015-01-20 17:55
    It seems to be hanging on any ee_put commands.... and the ee_get commands return nothing.. empty string...
    edited 2015-01-20 17:56
    JonnyMac wrote: »
    hmmmm.. ok.. going to try putting a resistor on it....
    edited 2015-01-20 17:59
    JonnyMac wrote: »
    That was definitely the problem.... me making assumptions....
    THANKS ! Wish I would have asked on here before scratching my head for hours..... live and learn
    edited 2015-01-20 18:20
    tj4shee wrote: »
    I wonder why these other EE routines don't bother driving the clock high since it's a single master system and for all practical purposes there isn't a slave chip that I know or I have ever come across that tries to pull-down the clock line anyway, certainly not EEPROMs. This is a problem with reading "standards" too literally or comprehensively without applying balance as a lot of this stuff in the standard just doesn't apply. SMB is basically I2C but without all that overhead that is never needed in a single-master system.
    The other thing is that the pull-up resistors that do get used are a bit light on in terms of pull-up anyway although fine for internal lower speed stuff could slew too slowly for high speed clocking and longer lines and more chips etc. Better off driving the clock push-pull rather than rely upon a pull-up.
    BTW, your eeput tests should have revealed it didn't work for lower eeprom too but I guess you were too "focused" on high eeprom :)
    As I always say, always be methodical and cross check and cross check the cross check etc.
    Good points... I am going to see what happens if I remove the resistor and programmatically drive the SCL high before access...
    TJ
