Linux rifle that's accurate up to a mile — Parallax Forums
edited 2015-01-19 12:29 in General Discussion
http://www.zdnet.com/article/the-trackingpoint-338tp-the-linux-rifle-thats-accurate-up-to-a-mile/#ftag=YHFb1d24ec
The TrackingPoint 338TP, the Linux rifle that's accurate up to a mile
First, the 338TP uses the .338 Lapua Magnum long-range rifle for its base. This rifle started as a design for a US Marine sniper rifle. Then, to acquire the target, the rifle uses a laser to enable you to "tag" your target. More than just a laser-targeting system, its sensors also track wind speed, direction, temperature, and barometric pressure. As serious shooters know, all of these factors must be taken into account for an accurate shot at great ranges.
This data is then passed on to the built-in Linux computer. Once you've tagged the target, the rifle will automatically track it. You then bring your reticule, the optical target-aiming point, to match the rifle's computed impact point. Once you've matched it up and you decide to take the shot, you pull the trigger and the TriggerLink computer works out all the details needed to hit the target. Thus, and this is surprising until you get used to it, there may be up to a second of delay between the time you pull the trigger and when the shot goes off.
    edited 2015-01-19 09:45
    One of such systems already deployed in military, uses RTOS. Chip was from STm
    edited 2015-01-19 09:56
    Yes, but I'd rather be shot by a rifle controlled with an Open Source OS and Free software than know that Wind River or whoever made a single cent out of my demise.
    Well, unless it an Ubuntu derivative that is :)
    edited 2015-01-19 10:02
    Heater. wrote: »
    @Heater
    I'd be careful... you might get your wish. Why? Well, open source OSes don't decide who gets the weapons system.
    Next generation is a robotic sniper rifle that shoots at the laser range finder.
    Linux, huh? I'd think that Windows' BSOD would be appropriate on a sniper rifle. With the emphasis on Death.
    A one-second firing delay seems like an eternity. So much for a moving target.
