Trouble Getting WAV Player to play audio from SD Card
Hi All,
I am trying to run a quick test to play a wav from SD Card on the Human Interface Board using the Simple IDE example file, but the DAC isn't pumping out any voltage. I also picked up an Activity Board, but it arrived dead and won't even turn on. What a waste of $50.
The code looks like this per the example, but I changed the filename to another wave.
If there is a String datatype, couldn't that work for this example file?
The best option would be to write bytes directly to one of the DAC channels but I can't seem to find any documentation on most of the components of the Parallax boards to get them working properly.
int DO = 0, CLK = 1, DI = 2, CS = 3; // SD I/O pins
sd_mount(DO, CLK, DI, CS); // Mount SD card
const char levels[] = {"0000001D.WAV"}; // Set up levels string
wav_play(levels); // Pass to wav player
wav_volume(6); // Adjust volume
pause(500); // Play for 5 s
