Changes to library not reflected in SimpleIDE
Having a very odd problem.... I have created several libraries under SimpleIDE... All was working fine..... Until....
I made some changes to a couple of procedures saved them and recompiled them as libraries.
But the changes I made are not seen by SimpleIDE ! Is it caching data ? If so, where do I delete the cache ?
It's odd because when I goto re-add the library (on my Mac) I can actually see the updated procedures if my finder window....
So I went and did a Copy File to my project.... Added the .c and .h files from the library. Again, I see the updated files in finder quick view... And add them... But when I open them in SimpleIDE I am seeing the old files....
So where is the cache and how do I delete it without creating problems ?
Thanks TJ
Thanks TJ
That was the answer ! Thanks ! I had started the library as part of a prior project.... so I had like named .c/.h files still in that folder.... deleted them and Eureka ! things are like I expect. I've been programming for 40 years.... you'd think I would have picked up on the local folder thing. Back to the basics....
