Spin conversion to C - confused by a Spin statement
Hoping someone can clear this confusion up for me.... I am not familiar enough with Spin....
I am trying to understand i2c in simpleIDE.... and the ONLY i2c program I have been able to get running was a Spin example I found for a PCF8574...
anyways... here is the Spin line I am trying to understand...
outa[SDA] := (data <-= 1) & 1
The way I interpreted this is .... data is bit-rotated left by 1, then ANDed with 1.....
but this doesn't make sense.... why rotate ??? if you are going to AND by 1, it wouldn't matter what was in the most significant bit... it would always end up as a 1 in the lowest significant bit....
and...... why do this at all... because the only real options to assign to out[SDA] would be a 1 or a 0.... isn't the result above always > 0 ?
The only thing I could think off is that a timing issue is being created in a complex way ?
Anyway, outa[SDA] := (data <-= 1) would be sufficient here (left side is only one bit -> implied AND).
EDIT: kuroneko is correct that "outa[SDA] :=" will only use the LSB of the right side, so the "& 1" is not necessary.
PRI Write(data) : ackbit '(SCL, data) : ackbit | SDA
'' Write i2c data. Data byte is output MSB first, SDA data line is valid
'' only while the SCL line is HIGH. Data is always 8 bits (+ ACK/NAK).
'' SDA is assumed LOW and SCL and SDA are both left in the LOW state.
___ackbit := 0
___data <<= 24
___repeat 8 ' Output data to SDA
______outa[SDA] := (data <-= 1) & 1
______outa[SCL]~~ ' Toggle SCL from LOW to HIGH to LOW
______outa[SCL]~
___dira[SDA]~ ' Set SDA to input for ACK/NAK
___outa[SCL]~~
___ackbit := ina[SDA] ' Sample SDA when SCL is HIGH
___outa[SCL]~
___outa[SDA]~ ' Leave SDA driven LOW
___dira[SDA]~~
The part I was missing was "outa[SDA] :=" will only use the LSB of the right side, so the "& 1" is not necessary...... The fact that outa will only use the LSB makes a big difference in resolving my confusion.... I just assumed (wrongly) that is would use the entire 32 bits of the data variable....
Which actually leads me to another question (and possibly a bad assumption)..... do all user-undefined variables default to "long" ?
