Chaining US Sensors
An interesting concept to combine two ultrasonic sensors to detect multiple echo returns. Doesn't apply to PING, only the HCSR04 type sensors with separate trigger & echo pins. Primary sensor works as expected to find closest object using echo signal, which also triggers the secondary sensor's timing cycle to listen for subsequent echoes. I haven't tried it myself.
http://letsmakerobots.com/node/36863
Yes: http://forums.parallax.com/showthread.php/134899
