$50 USB Power Pack for $9, Free Ship
Just buy one or two before they run out and we'll collectively figure out what to do with them later.
Motorola Universal Charger Power Pack 3000 for Apple iPhone, Samsung & More!
One for $8.99: http://www.ebay.com/itm/Motorola-Universal-Charger-Power-Pack-3000-for-Apple-iPhone-Samsung-More/191401749892
Or two for $14.99: http://www.ebay.com/itm/Motorola-Universal-Charger-Power-Pack-3000-for-Apple-iPhone-Samsung-More-2-Pak-/221595507338?pt=US_Cell_Phone_PDA_Chargers&hash=item33981f1a8a
http://www.droid-life.com/2015/01/09/deal-of-the-week-motorola-3000mah-power-pack-for-8-99-regularly-50-2-pack-for-14-99/
http://www.ebay.com/itm/390449318860
Thanks! Just ordered one.
Personally I'm not using power packs, but friends around often need them, so suggestion will help a lot.
There's a new erco in town!
Just received mine today. Plugged in and charging now.
BTW the package says 7000maH.
I haven't checked the cables yet, but they may be the "Power Only" type cables which are nasty because they get mixed in with the fully functional powered + data cables and can cause wailing and gnashing of teeth when you grab a cable.
The packages were marked 7000mah also.
I'm thinking of turning one into a robot chassis but I may need to wait for my 3D printer to show up to print a frame to fit around the battery and allow for mounting things. I just need to cross the line between thinking and doing!! )
I'm more than a little interested to hear how this goes.
By all means wrap a piece of tape around all such cables. Avoids much frustration later.
p.s. seller should pay me something for the advertisement. Just in january he sold more of these powerpacks, than he did in previous 3 months!
OK, I bought two.
erco, have you thought about going into sales?
Walter
Also, a partial answer to post #14 is that an 85 Ohm resistor as load (59 mA) does not keep the power on but a 50 Ohm resistor (100 mA) does. So the Tenergy unit makes a better charger than it does a portable power supply. For the latter, you'd be better off with a 3s RC Li-po and one of erco's previous deals - a high efficiency buck converter for a buck and change. http://www.ebay.com/itm/5pcs-DC-DC-4-5V-28V-to-0-8V-20V-Step-Down-Module-Power-Supply-for-Arduino-Hot-/301297751206
anyone tested real capacity, or checked, what's inside?
BTW, I like the idea of powering a string of WS2812's with it. That's the sort of steady and substantial load that will keep the device from turning off. It's a little OT, but the latest WS2812 widget I acquired, a 17cm ring containing 60 LEDs, is outstanding. http://www.icstation.com/icstation-ws2812-cascade-board-p-5313.html It provides great mood lighting! With a portable power pack, you can take it with you.
Page can't be displayed error.
