SIDE RC2 COGs in XMMC — Parallax Forums
RsadeikaRsadeika Posts: 3,901
edited 2015-01-09 07:23 in Learn with BlocklyProp
Below is a small test program to see if COGs are able to run in XMMC space, apparently not. This runs correctly in CMM, but, in XMMC..., led27() is not flashing. Is there something that I am missing? I think in the previous versions there was an error presented when compiling under those conditions. Of course I am using the Activity Board.
Ray
  test_mmc_cog.c
  Test if COG runs in XMM space.
#include "simpletools.h"
void led27();
int main()
  // Add startup code here.
  int *cog1 = cog_run(&led27, 10);
  while(1)
    // Add main loop code here.
    high(26);
    pause(500);
    low(26);
    pause(500);
  return 0;
void led27()
  while(1)
    high(27);
    pause(200);
    low(27);
    pause(200);
    edited 2015-01-09 06:55
    This only works with the version of propgcc in the default branch on Google Code. It doesn't work with the version that is included with SimpleIDE at present.
  • RsadeikaRsadeika Posts: 3,901
    Well it looks like we will have to wait for RC5? :-) At least the SDXMMC and XMMC External... works, I think. Yesterday I did a prelim test and it seemed to be working, will have to push it some more today. But, it sure would be nice to have COGs running in extra large memory models.
    Ray
