Small led matrix display with high pixel density and(or) smaller gaps between pixels?
CuriousOne
Hello.
I want to build a simple wearable device, for which I need 7x5 led array to display info I need. It should be as small as possible and look as cute as possible
The problem with available 5x7 dot matrix leds is that either their "pixels" are huge, say 1-2mm in diameter, they are round and have large gaps between pixels, so it is hard to establish a solid image, or they might have smaller "pixels" such as LTP-305G pictured in attachment, but distance between pixels is still huge and they are again round.
Any ideas/models?
Any ideas/models?
Sparkfun Light Pipe: https://www.sparkfun.com/products/10694
Found some smaller diameter light pipe to make a tighter display on eBay at a better price:
http://www.ebay.com/itm/10-3m-1-5mm-optical-fiber-ESKA-CK-60-fibre-optic-lighting-light-pipe-Mitsubishi-/261698416671?pt=LH_DefaultDomain_0&hash=item3cee70f01f
Sure, there are oled displays, but they are all fancy, with SPI/I2C etc etc to play around, led matrix is dead simple solution
http://www.dx.com/p/0-96-128x64-i2c-interface-white-color-oled-display-module-for-arduino-avr-arm-pic-346540?tc=CAD&gclid=CMGMzvOrh8MCFQotaQodLAsA-Q
I know you want simple, but I2C is very easy to deal with, imo simpler than multiplexing a 5x7 led matrix, and is ready to use. This one is much higher resolution than 5x7 but there are other choices available.
It is I2C though
or maybe this one http://www.adafruit.com/products/458
I have not used the Basic Stamp at all, but I have used the propeller for I2C and multiplexing led displays with no issues. For sure either one of the displays Ron posted will work with the propeller. Time to move up?
These little OLED displays work great with the Prop.
Here's one in an aluminum wallet.
And another powered from a Prop's I/O pin.
The display is plugged directly into the QuickStart's I/O pins.
These displays were $5. I do have them configured in SPI mode. I had trouble using them in I2C mode.
Or just red for a lot less money:
https://www.futurlec.com/LED/LEDMS88Rpr.shtml
Yes that red square matrix is great, but pixels are huge - 3x3mm each. If it was at least 1x1mm....
That would be nice, but I can't find that anywhere. Here's a smaller one but has closely packed rounds 1.9mm LED's:
http://www.ebay.com/itm/5-pcs-LED-Display-Dot-Matrix-Common-Anode-Red-1-9mm-8x8-20x20mm-/330738177797?pt=LH_DefaultDomain_0&hash=item4d01881705
Still, they must be made as this watch uses one.
http://www.ebay.com/itm/Personalized-Signature-3D-Pedometer-Smart-Watch-8GB-Flash-Drive-LED-Display-/251787080809?pt=LH_DefaultDomain_0&hash=item3a9fadf469
Maybe buy one and see if it's hackable, it looks to be a 11 x 7.matrix.
In theory, a lot of languages can handle I2C, but it does not worked in my case.
For the leds, I have the 5x7 matrix using these 1.9mm leds, but they are still round and huge
For the watch display, I've bought similarily looking watch, hoping to salvage display from it. It uses small, caseless led chips, directly soldered to pcb, and enclosed in plastic divider, which forms "pixel"
http://www.ebay.com/itm/5x7-Square-LED-Dot-Matrix-Display-/121446723816?pt=LH_DefaultDomain_0&hash=item1c46c9f0e8
Compare to dimensions of LTP-305G, which I'm using currently:
http://www.digikey.com/product-detail/en/LTP-305G/160-1001-5-ND/121279
