Ten Year Old Mars Rover is Having Senior Moments
So is computer memory just a flash in the RAM? Opportunity knocks once, or so it recalls after waking up to failing memory and forgetting data and what it has already accomplished. Robo-dementia rocks!
https://screen.yahoo.com/nasas-mars-robot-losing-mind-153026178.html
But the rover on the video is not Opportunity, its Curiosity who has been there just a couple of years.
It took a coulpe of years to get to Mars. Add to that probably 5 years to build and you have around ~17 years.
Most likely they are actually using EEPROM chips. I bet that all the testing of the electronics systems was done (heat and cold recycling, and reprogramming) using the same sets of boards. Reprogramming cycles of these chips was not as good as chips today. The chips have just been reprogrammed too many times.
Hopefully they can isolate the banks causing issues so thdy can squeeze further life out of this rover. It may just be a single or few bits that are failing today, but its likely there will be a lot more failure bits coming soon, depending on how they have been rewriting the memory.
BTW Lets hope the new NASA designs dont use 22nm or smaller chips (such as the latest x86 or ARM, etc) because it is expected these chips will only have a 10 year life. The metal layers are not truly solids and so the metal lines flow, and over time are expected to go short or open circuit. Those 10 years are from chip manufacture date, not usage!
This likely includes the newer DRAM and Flash too.
It is going to become difficult to build Voyager style probes with the latest chips
Voyager 1 and 2 have been going for ~35 years so far, with computers predating the Apple, and IIRC use tape as mass storage as there is so little RAM.
I wonder how well this custom chip is holding up:
http://micro.magnet.fsu.edu/creatures/pages/marsroverdarkfield.html
Nice article - I had missed this one.
