Film for IR light sensor
I got in these sensors from Sparkfun
https://www.sparkfun.com/products/12787
I want to drill a small hole in a face plate and put this behind it out of site, and want to cover the rear of the hole with some black film that will hide the sensor but still allow the IR to pass with the least reduction. Is there something off the shelf that will work, like at a photography store? I am sure there are products for this purpose but not sure what the name of it is.
Here's a link to a polyester film filter. 87C filters are also available in glass and gelatin (I have some of this stuff from my infrared photography days).
I think there's also some plastics which are opaque to visible light but transparent to near IR.
I'd try Googling for "infrared transparency", "infrared transparent plastic" or something along those lines. Assuming the space behind the hole opening is dark, I'd bet there are a lot of cheap things that would work.
Forrest Mims often recommended exposed color film in his books and articles, but that may not be easy to find these days.
In case you actually do want to block everything else, here's the first hit for infrared transparent plastic:
http://www.eplastics.com/Plexiglass_Acrylic_Sheet_Infrared_Transmitting
Tom
If not, then Tom's photo film suggestion has merit. It's common practice to put passive IR receivers behind materials that are visibly opaque but transparent to IR.
May be too much attenuation as erco suggests.
I know the Parallax Gesture Sensor works though glass, but have not tried any colored glass.
http://www.avagotech.com/pages/en/optical_sensors/integrated_ambient_light_and_proximity_sensors/apds-9960/
It doesn't mention the IR component.
This sensor is starting to sound interesting. I might have to get one to stack on top of my very tall "to play with" pile of cool stuff.
Of course you know that was not my intention.
When I got my Parallax Gesture Sensor, I did a lot of investigations an these devices. I guess that's why I don't post much code, because I'm always researching.
