Non volatile storage possibilities investigation — Parallax Forums
HarpritHarprit Posts: 539
edited 2015-01-10 23:02 in Propeller 1
Is there a way to store a changing variable that can then be re-read on the next powering up of the Prop?
Is there a way to access the EEPROM to store this variable? Will this be viable (re read able) if the EEPEOM is then not disturbed?
On the other hand is it possible to store in HUB memory and will the variable be available on reload of memory if the Prop was not powered down?
I want to store the last position of a CNC machine just before shut down.
H
    edited 2015-01-04 10:59
    Harprit wrote: »
    I want the store the last position of a machine just before shut down.
    H
    This object:
    http://obex.parallax.com/object/23
    lets you write to the EEPROM. You would probably want to write from $1FF down, ( top of the 32K EEPROM), or if you have a 64K EEPROM, you could use from $200 up.
    EDIT: That would be $7FFF down in a 32K EEPROM and $8000 up in the 64K EEPROM
    edited 2015-01-04 11:00
    Yes, the variable can be stored in eeprom and read back on power up. The only issue is the number of write/erase cycles an eeprom location can endure.
    No, anything stored in hub ram will disappear when power is turned off.
    If a large number of erase/write cycles are required you can take a look at various non volatile ram options like battery backed ram and fram.
  • jmgjmg Posts: 15,199
    edited 2015-01-04 11:06
    Harprit wrote: »
    H
    Both can work, usually you checksum (or store X, !X etc) so there is some valid-check on what you read.
    eg in the Prop case a deep power down will corrupt the saved value, but a code reload with power sustained is ok.
    Likewise on a EEPROM, a brand new part will have invalid XYZ data.
    Data writes up to the Page size take the same time, so you can have quite a few bytes to play with.
    If this changes a lot, or uncontrolled off is common, then FRAM can be better than EEPROM, as it has faster writes and no practical endurance limits.
    On a machine, you might drop the write cycles, by saving LastX,NewX, on a rotating page basis
  • HarpritHarprit Posts: 539
    edited 2015-01-05 13:00
    Thanks guys.
    H
    edited 2015-01-05 14:29
    a nice feature of the propeller eeprom boot is that the checksum of the boot image is just checked while programming the image with the propeller tool (or whatever else)
    at boot time the propeller does not care about the checksum of the eeprom.
    Now comes the funny thing. The content of the eeprom gets copied into the ram. Thus eeprom addresses and ram addresses are the same.
    This leads to a quite nice feature in spin.
    Lets say you have a variable with predefined content, say a long value in your dat section, named 'mySettingValue' containing - say - 12345 or whatever.
    Programming the eeprom will write 12345 to that memory location of the eeprom and the propeller will load (boot) from the eeprom and has a value of 12345 at the memory location @mySettingValue in ram and in the eeprom.
    So the address is the same in ram and eeprom.
    At runtime your program can now write the value of the ram location at address @mySettingValue to the same address in the eeprom and after a reboot the NEW value of mySettingValue will be booted by the propeller into the same location in ram as 12345 was loaded before.
    a simple eeprom.write(mySettingValue,@mySettingValue) will save the value from ram to eeprom. You will not need to do anything to retrieve that value, while booting the propeller will just populate the ram with the value saved in eeprom and you are good to go.
    This is IMHO the easiest way to save persistent setting in the eeprom.
    2 things to watch out for.
    This method uses the standard eeprom size of 32K and manipulates the standard boot eeprom content So if your reload your program from PropTool or whatever you use the setting will be gone and overwritten by the standard value in the source.
    To avoid that (say for calibration data or so) you need to save the persistent setting in the upper eeprom (>32K). Then it will survive reloading the eeprom with a new program but you also need to read in the setting from there at your application startup.
    And not all Propeller boards have 64K eeproms. Some still have 32K an there is no upper half of eeprom available.
    my two cents!
  • edited 2015-01-05 15:12
    Harprit wrote: »
    I've been using a DS1302 to save data between sessions. The attached file will give you an idea of what's required. The advantage of this approach is you don't have to worry about wearing out the EEPROM. You do have to include a standby battery for the DS1302 though.
    Sandy
  • TubularTubular Posts: 4,768
    edited 2015-01-05 15:17
    If you're not talking about massive downtimes, a supercap can help retain the data. The prop takes of the order of a few microamps using rcsclow.
  • JDatJDat Posts: 103
    edited 2015-01-05 15:32
    Thank you msrobots for explain.
    I am using second method (store in upper eeprom part), because first method for some reasons didn't worked for me. Bugs in my code?
    CON
    'User constants
            pixelcount=100
            maxframes=50
    CON
    ' System constants
            _clkmode = xtal1 + pll16x                                     'Standard clock mode * crystal frequency = 80 MHz
            _xinfreq = 5_000_000
    '' Next two lines borrowed from JonnyMac
    '' Thank You, it great idea!
            CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq               ' system freq as a constant
            MS_001   = CLK_FREQ / 1_000                                   ' ticks in 1ms
            txpin=30
            rxpin=31
            i2cSCL=28
            i2cSDA=29
            EepromStoreAddress     = $8000
    OBJ
            debug     : "FullDuplexSerial"
            EEPROM    : "I2C PASM driver v1.4"
    PUB Main | a
        debug.Start(rxpin,txpin,%0000,115_200)                    'start proppulg serial
        EEPROM.start(i2cSCL,i2cSDA,400_000)                 'init eeprom
        readeeprom                  'read eeprom
        'do some stuff like launch new cogs etc
        repeat
          a:=0
          'do some stuff in loop
    DAT
    liveframe     long  $00_00_00_00[pixelcount]    'this will not be saved
    eepromsavestart         ''selfexplain
    frames        long  $00_00_00_00[(pixelcount+1)*maxframes] 'this will be saved in upper eeprom part
    eepromsaveend           'selfexplain
    PUB wipe 'clear EEPROM storage and RAM
        longfill(@eepromsavestart,0,constant((@eepromsaveend-@eepromsavestart)/4))
        writeeeprom
    pub readeeprom 'Load from EEPROM to RAM when booting
        eeprom.read_page(eeprom#eeprom,EepromStoreAddress,@eepromsavestart,constant(@eepromsaveend-@eepromsavestart))
    pub writeeeprom|i 'save from RAM to EEPROM
    '' Loop for pagewrite because there are 64 bytes in one page
      repeat i from 0 to constant((@eepromsaveend-@eepromsavestart)/64-1)
        eeprom.Write_page(eeprom#EEPROM, EepromStoreAddress+i*64, @eepromsavestart+i*64,64)
    pub dumpram|i ''dump RAM contents to serial debug terminal
      repeat i from 0 to @eepromsaveEnd-@eepromsavestart-1
        if (i//16)==0
          debug.tx(13)
          debug.hex(@eepromsavestart+i,4)
        debug.tx(32)
        debug.hex(byte[@eepromsavestart][i],2)
      debug.tx(13)
    DAT
    MIT licence bla bla bla
  • tonyp12tonyp12 Posts: 1,951
    edited 2015-01-05 15:56
    The PCF85263A RTC provides a free RAM byte, which can be used for any purpose, for example, status bits of the system.
    It also have 3 timestamp memory to store when something happened.
    This is RAM, but will not be lost as you supply a tiny battery that it auto-switch over to when main power is gone.
    http://www.mouser.com/ProductDetail/NXP-Semiconductors/PCF85263ATL-AX/?qs=sGAEpiMZZMtpeOq%2f1QMb1R3j9P4FFFLvmvjwceenyyw%3d
    if you need 64bytes of RAM
    http://www.mouser.com/ProductDetail/NXP/PCF85363ATL-AX/?qs=%2fha2pyFadugCB5rfANsExNtXYfVl%2f4QeZ6stefccCRI%3d
    edited 2015-01-07 20:54
    Where can I find the I2C ....V1.4 driver
    H
    edited 2015-01-08 00:42
    I am using this driver: http://obex.parallax.com/object/700
    edited 2015-01-08 19:03
    Thanks again
    H
  • redheadedrodredheadedrod Posts: 78
    I am just happening across this thread and it brings a couple questions to mind.. I am a newbie with this and I am hearing a couple things I am not aware of...
    How do I know the size of my propeller eprom? 32k 64k? I have an older board that was part of a learning package with the bread board and lots of components already onboard. I just received 5 of the Rev C Activity boards I bought with the defect..
    I do have a need for non-volitile memory as well to store log files and since it will be in an automotive environment I do NOT want to use the SDcard to store a log file and I want it to survive power off cycles. (I will be logging the CAN BUS from my truck and saving it to a connected PC once in a while. Could stay off for up to a week but will have access to the secondary automotive battery which will remain separate from the primary battery and only power my computer devices when the vehicle is off. This vehicle has 10.3k baud rate and is actually GMLAN which uses a CANBUS type protocol but much simpler hardware.)
    What is FRAM?
    I would LOVE if I could get a gig of storage but I guess it all depends on what is practical.
    I will likely setup a log file that rolls when it gets full.
    Rodney
