Raise your hand if you have a mill or lathe — Parallax Forums
GordonMcCombGordonMcComb Posts: 3,366
edited 2015-04-21 08:08 in General Discussion
I'm collecting some basic factoids regarding the prevalence of machine tools among robotics/electronics experimenters. Raise your hand if you own or use (business, school, etc.) a metal lathe or vertical mill to help construct your projects!
    edited 2014-12-30 15:00
    I cheat - I have my brother make stuff. I'm sure he uses that stuff.
    edited 2014-12-30 15:08
    I have a ShapeOko CnC Mill, does that count?
    Hoping to add a 3D printer soon...
    edited 2014-12-30 15:11
    I have a Taig hobby lathe. I don't make much with it though.
    edited 2014-12-30 15:44
    I've built a JGRO CNC
    edited 2014-12-30 16:13
    CNC mill here. I haven't used it much after getting the laser cutter, though.
    edited 2014-12-30 16:48
    Yup, and a Unimat at home.
    Somewhere.
  • Mark MaraMark Mara Posts: 64
    edited 2014-12-30 17:08
    I like old machine tools. I have a 1900 Hindey lathe and a 1890 Baker MillI, both flat belt drive. My good lathe is a 1966 Monarch 10ee.
    -markM
  • sidecar-racersidecar-racer Posts: 82
    edited 2014-12-30 17:10
    I have a Jet 8" lathe
  • pjvpjv Posts: 1,903
    edited 2014-12-30 18:10
    Since you asked.....
    For my business I have 2 CNC mills with 33 inch travel; one has a 4th axis, so we can do contour milling. There is also a third one with 12,000 rpm 10 HP spindle on the way. Each has a 26 station automatic tool changer, and can handle 1000 pound load.
    We also have a CNC lathe with 16 inch swing.
    Cheers,
    Peter (pjv)
  • Paul K.Paul K. Posts: 150
    edited 2014-12-30 18:43
    I love robotics and work on projects all the time. I've bought some stuff to make a few bots.
    My List of machines.
    Grizzly G0463 Mill converted to CNC.
    CNC Router a Pro4848 from CNCRouterparts.com. (24K RPM Max)
    Grizzly Stroke Sander(Finish Aluminum for anodizing)
    Bridgeport CNC with a Fagor 8055 controller. (Brand new as of last year)
    Bridgeport from Woodstock era(manual control), its solid, just smells funny.
    And a old lathe that I just stare at. I don't know how to use it.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-12-30 20:14
    I have a 7x14 metal lathe.
  • LeonLeon Posts: 7,620
    edited 2014-12-30 22:03
    I have a Taig lathe.
    edited 2014-12-30 22:16
    I've got a humble Harbor Freight metal lathe that in years past was used to fabricate all sorts of odd pieces for all sorts of projects...well beyond just electronics. I also mounted a cross-vice to a drill press 20 years ago to do light-weight milling and drilling of pcbs and cases. It still gets used occasionally.
    In the spirit of full disclosure, though, nearly everything I make nowadays involves wood, foam, cardboard, PVC, or mud. So the tools have devolved accordingly.
    edited 2014-12-31 00:40
    Currently sourcing the final parts for a custom sized Shapeoko CNC that will have a Bosch router for its milling tasks to cut larger gantry plates for a 36"x60" 8020 based CNC, but the router will be replaced by a high res USB camera for the Shapeoko gantry's true purpose.
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-12-31 03:36
    I have a little Proxxon MF 70. I use it mostly for making odd shaped holes in front panels and for cutting circuit boards.
  • JohnR2010JohnR2010 Posts: 431
    edited 2014-12-31 04:40
    I have a 32" ShopBot Buddy and a Zing 40watt laser use both several times a month.
  • LynnLynn Posts: 33
    edited 2014-12-31 05:16
    I have a Taig lathe and mill.
    edited 2014-12-31 08:22
    Raise your remaining hand if you have a planer/joiner, said to be the most dangerous tool in the wood shop!
    edited 2014-12-31 09:02
    Thanks for the feedback, all. Seems that lathe and mill ownership is something of a minority, but not unheard of!
    edited 2015-01-01 10:44
    Gordon, not the most scientific survey--You can also say, "16 out of 17 respondents replied in the affirmative"!
    I have a Myford ML7, old, but still a workhorse around the shop. Not NC. Also a drillpress with 2-axis cross-slide. Thinking about getting something like a Shurline to make NC for faster prototyping in PC and Styrene boxes.
    216 x 211 - 10K
  • FredBlaisFredBlais Posts: 380
    edited 2015-01-01 10:57
    I was deciding between buying a laser cutter or CNC mill for my first tool. Is there any reason why you are using the laser cutter more? What model is it?
    The laser cutter seems nice for engraving stuff and cutting acrylic, but what else can it be used for?
    Fred
    edited 2015-01-01 15:36
    IMHO, cutting acrylic has a ton of uses, and people are just settling for them. It's cheap, looks cool, can be formed easy, etc...
    @Gordon: I have access to both.
    edited 2015-01-01 16:10
    FredBlais wrote:
    I was deciding between buying a laser cutter or CNC mill for my first tool. 1. Is there any reason why you are using the laser cutter more? 2. What model is it?
    3. The laser cutter seems nice for engraving stuff and cutting acrylic, but what else can it be used for?
    1. Most of what I was doing with the CNC mill was 2D cutting of FR4 fiberglass. Although the laser is a poor choice for FR4 (it chars), it can cut other materials that have useful characteristics.
    2. I have a 35-watt Epilog Zing16.
    3. I've used mine to engrave and cut acrylic, wood (including plywood), acetal copolymer (like Delrin, very handy for tough mechanical parts like gears), rubber (for gaskets), cork, mica, paper, Formica, nylon sailcloth, magnetic sheet material, matboard, leather, conductive foam, and rubber stamp material. I've also engraved glass, marble, and granite. Although it will not cut or engrave metal, I've used a spray material for printing on metal by fusing the dried spray to the metal, the rest of which gets washed off. (This would also work as an etchant resist for making PCBs, BTW.) You cannot cut anything that contains chlorine, such as PVC, due to the noxious and very corrosive fumes produced.
    One huge advantage a laser cutter has over a CNC mill is that, once you have a ventilation system installed and a source of compressed air, there's nothing left to buy, except for exchanging the laser tube for a new one every five or so years. When I bought my CNC mill, that was just the leading edge of the spending spree. There's fixtures and collets and bits, oh my! Vises and wrenches and grease, oh no! The list goes on ...
    When I bought my laser cutter, I had no idea what I was going to do with it. I just knew I wanted one. Now I could not function in my business without it. The CNC mill doesn't sit completely idle, however. The are still prootype PCBs to depanelize and the occasional metal-cutting job.
    My only other stationary power tools are a drill press, disk sander, and horizontal bandsaw, all of which get used a lot. A small manual lathe would come in handy, as would a vertical metal-cutting bandsaw. I'd have to have a garage sale first, though, to make room.
  • W9GFOW9GFO Posts: 4,010
    edited 2015-01-01 17:31
    Lathe, CNC mill (with 4th axis) and laser here, some other stuff too.
    The laser gets the most use. Partly because it makes money to do so. The lathe gets used more than the mill but of course there are some things that only the mill and it's fourth axis can do.
    Lets not forget the 3D printers, they gets lots of use too.
    I think if I had to start over it would be Laser, 3D printer, lathe, then mill.
  • T ChapT Chap Posts: 4,260
    edited 2015-01-01 18:59
    I have a Camaster Stinger1. I cut delrin and aluminum non stop, requiring pocketing, drilling, tapping(threadmilling), engraving, beveling, surfacing. You have to buy a tool for what you need to do. A laser has some benefits, but a lot of drawbacks compared to a CNC in terms of materials and cutting options.
    400 x 400 - 79K
    edited 2015-01-01 19:04
    I have a Harbor Freight 7x10 lathe which I've enhanced with a quick-change tool mount. I don't use it much and I don't get fancy (I've never changed the gears or attempted threading) but every once in awhile it's the only tool for the job.
  • Mark_TMark_T Posts: 1,981
    edited 2015-01-02 13:45
    Have access to Myford lathe and Warco turret mill at local Makespace, but the machines that get by far
    the most use are laser cutters, since there's so much simple prototyping(*) can be done quickly and safely
    with them. Lathe is invaluable for some stuff, and milling I do a few little things under supervision at the
    moment. That will gradually change I think.
    (*) for instance its fairly trivial to make sprockets and gears in acrylic for light duty, bearing holders, boxes,
    mounting plates, etc etc.
  • ellipserellipser Posts: 43
    edited 2015-01-02 21:59
    Bridgeport milling machine
    Atlas/Craftsman lathe with change gears
    Home-made CNC router with Dremel attachment.
    Welder too.
    edited 2015-01-03 12:14
    LittleMachines mini-lathe, noname drill press, roland EGX-350 engraver.
  • Paul Sr.Paul Sr. Posts: 435
    edited 2015-01-05 15:22
    I have a Grizzly 7X14 Lathe and Grizzly Benchtop Mill. I have converted the Mill to CNC - mechanics work superb but I am still trying to figure out how to MAKE something!! LinuxCNC is a bit of a puzzle and I am NOT a machinist!!
