Problem with the Prop Plug — Parallax Forums
Private19872Private19872 Posts: 61
edited 2014-12-25 12:37 in Propeller 1
I just received the Prop Plug ( http://www.parallax.com/product/32201 ) and plugged it into my breadboard. My computer was searching for drivers and found one to use but it says it had an error installing. My computer worked fine with my DemoBoard but not with the Prop Plug. Is there anywhere I can download a driver manually for it?
  • RsadeikaRsadeika Posts: 3,882
    edited 2014-12-25 12:19
    If you go to the link you just posted, and drop down to the Downloads, there is a .pdf file that shows you where you can find a driver at the Parallax site. Before it used to be easy to find the necessary drivers, now you have to do a search at the Parallax store.
    I just started messing around with the Prop plug and my Widows 7 did not have any problem finding a driver.
    Ray
  • Private19872Private19872 Posts: 61
    Thanks, I don't know that the driver I downloaded worked, because it looked like Windows searched the internet for the driver again, but it doesn't matter though because now it's working and I have a COM 14.
