Do I have to solder this in a special way?
http://www.parallax.com/product/32313
I recently purchased this and when I got it, I noticed the solder points were smaller than I had expected. Do I have to solder this very carefully or is there something different I need to use? Thanks for your help.
The smaller tip the better.
In other words, I first apply a coating of solder to all the pads that I am going to use without any component placement. This is just a thin coat of solder, but that makes attaching the component a simpler job. Bare metal that hasn't been tinned sometimes rejects solder due to oxide, dirt, or oil. By first tinning the pads, you avoid struggling with rework that might otherwise be required.
For those that don't know, it takes the heat from the soldering iron and cleans the bare copper (or other metal), so that the actual solder will stick. If the copper is discolored from age, it might be best to start with an abrasive pad (the plastic ones I use to clean pots and pans) to get to bright copper before expecting the flux to do its job.
Not all flux is for electronic projects -- some are too strong and create later problems (like Acid core solder).
Others might be okay for electronics, but don't clean up very easy (like Rosin core solder)
It may be best to use a solder that doesn't provide a flux in its core and to get either a paste or liquid flux that will clean up more easily.
Paste flux usually requires a solvent to clean up as it tends not to mix with water.
Liquid flux usually cleans up with soap and water.
Tinning can be done to everything that you think might give you trouble -- pads on the board, components, and wires; but don't use excessive solder as that creates a mess and additional problems. (You may need a bit of practice with tinning to get it right.)
None of these things are 'special solder skills'. They are the skills and knowledge that apply to soldering just about anything.
I tried that when soldering surface mount LEDs. The problem was that having tinned the pads on the PCB it was no longer possible to sit the LED tight flush down onto the board due to the layer of solder in the way. That meant the LEDS ended up skew. Better was just to position the LED on the naked pads and tack down one end, position nicely whist the solder is molten. Then solder the other end of the LED.
I love the way people who know what they are doing solder fine pitch SMD chips. Flux the PCB pads. Position the chip and tack down one or two corner pins. Seemingly flood the pins with what seems like far too much solder, "drag soldering", that shorts everything out. Never mind messing with fine tipped irons use something that seems far too big for the job.
Then, drag the solder away from the pins with the iron and perhaps remove the excess with solder wick. Voil
But there are some things that do work with a soldering iron and SMDs.
LEDs and other two-point components (resistors, capacitors, and such) can be very difficult to get right. They may actually be harder than multi-lead chips.
So Heater has a good point. It may be best to stick everything down with gooey flux or to only tin one pad and then set the item where you exactly desire.
For chips with multi-lead packages, I tack one corner and then a diagonally opposite corner before doing the rest. That assures that the alignment is reasonably good.
Another way to go with tinning pads is to electroplate tin or lead to the pads. This can be done, but it rather involved technically. You need a solution with the tin or lead in it, and some apparatus to plate with a brush that wetted with the solution. (Too involved for my projects.)
Always amazed me. "What? You mean my board goes in that dangerous looking tsunami of molten solder and actually comes out all neatly soldered up without getting fried? No way!"
Works a treat though. After somebody has tuned up the process.
Yep, works well when tuned, but boy can it ever produce cold solder joint problems down the road if not tuned and operated properly.
