is there a debug with serial port basic stamp? — Parallax Forums
mistyreinymistyreiny Posts: 2
edited 2014-12-25 03:44 in BASIC Stamp
I know that there is a debug option with usb programmed and controlled basic stamps, but is that option also available when you use serial port communication to the basic stamp?
I mean specifically where the basic stamp can communicate back to the computer screen. Eg. put up a resistance of the potentiometer you are turning with your fingers.
  • ElectrodudeElectrodude Posts: 1,682
    edited 2014-12-19 15:16
    Yes. You use it exactly the same way - the USB thing is just a converter that gives you a serial port on computers that don't have one (or enough). Neither the stamp nor the stamp editor know or care about the difference between a real serial port and a USB converter.
  • mistyreinymistyreiny Posts: 2
    edited 2014-12-19 17:02
    thank you electrodude
    I did not want to buy the serial portion, wait 2 weeks then find out the debug fails.
    Thank you.
  • 72sonett72sonett Posts: 82
    edited 2014-12-21 13:20
    I use a BS2Sx on a StampDuino carrier board that has a USB connector. Stamp editor and debug work OK.
  • ajwardajward Posts: 1,130
    I have an older Dell desktop that I use for Stamp programming occasionally and Debug works just fine thru the serial connection.
