RPi - Anyone used these boards? — Parallax Forums
JonathanJonathan Posts: 1,023
edited 2014-12-20 19:28 in Propeller 1
Hi All,
I'm ready for desert. Has anyone used these boards?
http://www.100randomtasks.com/raspberry-icing
Or have any other recommends?
Thanks!
Jonathan
    edited 2014-12-19 11:39
    Wow! I didn't even know of the board's existence. But I do now. Thanks! :)
  • abecedarianabecedarian Posts: 312
    edited 2014-12-19 11:49
    Only A & B, not B+ compatible.... Too bad. :(
    edited 2014-12-19 12:07
    I'm sure they will catch up with the B+ soon. Many suppliers of Raspi boards have been caught out by the B+ upgrade.
    Anyway if you want to program a random Propeller board from a Pi we have https://github.com/ZiCog/pi-propeller-load
  • Mark_TMark_T Posts: 1,981
    edited 2014-12-19 15:07
    Interesting board, ditto the thanks for pointing this out.
    The pinout's the same for the first 26 pins so they probably are compatible electronically - and there are no
    tall connectors on the A+/B+ so the cut-out shouldn't matter.
    Would be interesting to see if it can be squeezed into HAT form (the RaspPi shield standard
    for A+/B+ boards), and whether the EEPROM can be shared as a devicetree ident chip.
    [ edit: Looking at the A+ I have it seems the GPIO pin connector has moved along to make
    room for a mounting hole, so the board probably doesn't fit on A+ B+ boards after all, or not
    without a bit of fudging ]
  • JonathanJonathan Posts: 1,023
    edited 2014-12-19 20:33
    Well, I went ahead and ordered two. I have two B's so they should be fine. I'll let ya'll know how they work!
  • pik33pik33 Posts: 2,394
    edited 2014-12-19 23:53
    WOW!
    I didn't even know it exists.
  • David BetzDavid Betz Posts: 14,516
    edited 2014-12-20 07:32
    There is also Bill Henning's board of course: http://www.mikronauts.com/raspberry-pi/robopi/
    edited 2014-12-20 07:37
    David Betz wrote: »
    Just beat me by a minute or two!!
    Two thumbs up for Bill's board!
    But as always, the more Props, the merrier!!
    edited 2014-12-20 08:02
    Thanks Guys!
    FYI: RoboPi is supporting the following platforms: (and has been tested with them)
    - Raspberry Pi Model A
    - Raspberry Pi Model A+
    - Raspberry Pi Model B
    - Raspberry Pi Model B+
    - Banana Pi
    - stand alone operation (needs 5V, PropPlug)
    Untested, but should work "out of the Box" with:
    - Raspberry Pi Compute Module (connect 5V, GND, TX, RX, GPIO#17)
    - Banana Pi Pro
    - Banana Pi R1
    - ODROID-W (connect 5V, GND, TX, RX, GPIO#17)
    More supported platforms early 2015!
    (including Banana Pi M2)
    edited 2014-12-20 09:48
    "raspberry - icing". Another example that engineers are not so good at cute.
    Seems to be popular despite the unfortunate name, there's only one left.
    Mark_T wrote: »
    B+ has two more USB ports stacked on the edge of the board, and the USB and Ethernet 'plugs' are mostly flush with respect to each other, so if you're looking at it with the Ethernet jack on the left, there are 4 USB ports to the right, the audio jack has moved over behind the Ethernet jack, composite video has been merged into that jack, and all done so for more "GPIO" and some other slight changes
    R-Pi B:
    R-Pi B+:
