Need help getting propellent.dll and C sharp working together
I'm not sure what changed here, but I used to be able to call the propellent dll inside of c sharp (Visual Studio 2008/Win XP) and query my USB ports and get a response from a port with a version number, among some other serial info.
I tried this today at work and it is not working (Visual Studio 2012/Win 7 64bit). Is there a compatibility issue with 64 bit OS's or something else? I'm going to go home and look for my old app, but I'm not too confident I will find it.
If anyone has a small demo app to query the com ports and get the return value from the prop, that'd be even better.
Anyway, I got it working and the code is a little sloppy, so I want to clean it up first and post it in case anyone else has this question. I don't know how many of you have any interest in .net and c sharp, but maybe this will help someone?
The only thing I'd like to get rid of is the propellent dll port search splash screen and the message box window, which I don't know of a way to suppress? Maybe parallax could add a switch in their propellent.dll code to suppress those both or make them generic if you didn't want to advertise your hardware components?
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Text; using System.Windows.Forms; using System.IO.Ports; using System.Text.RegularExpressions; using System.Threading; using System.Runtime.InteropServices; using Microsoft.Win32; namespace SimpleSerial { public partial class PropellerSerialForm : Form { // Add this variable string RxString; [DllImport("user32.dll", CallingConvention = CallingConvention.StdCall, SetLastError = true)] static extern IntPtr FindWindowEx(IntPtr hwndParent, IntPtr hwndChildAfter, string lpszClass, string lpszWindow); [DllImport("user32.dll", CallingConvention = CallingConvention.StdCall, SetLastError = true)] public static extern IntPtr FindWindowEx(IntPtr parentHandle, IntPtr childAfter, string className, IntPtr windowTitle); [DllImport("user32.dll", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Auto)] public static extern int FindWindow(string strClassName, string strWindowName); [DllImport("user32.dll", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Auto)] static extern IntPtr SendMessage(int hWnd, uint Msg, int wParam, int lParam); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern void InitPropellent(IntPtr winHandle, bool storePrefs, string regPath ); public IntPtr Handle { get; set; } public IntPtr HandleFake = (IntPtr)20; [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern IntPtr GetPropellerVersion(); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern void ShowEditPorts(); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern IntPtr GetPorts(); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern IntPtr GetSerialSearchRules(); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern void SetGUIMode(int mode); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern void GetResetSignal(); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern void SetResetSignal(); [DllImport("Propellent.dll", CallingConvention = CallingConvention.Cdecl)] public static extern void FinalizePropellent(); public const int WM_SYSCOMMAND = 0x0112; public const int SC_CLOSE = 0xF060; // public static extern int SendMessage(int hWnd, uint Msg, int wParam, int lParam); private void Form1_FormClosing(object sender, FormClosingEventArgs e) { if (serialPort1.IsOpen) serialPort1.Close(); FinalizePropellent(); } public PropellerSerialForm() { InitializeComponent(); cbxSerialSpeed.Items.Add("115200"); cbxSerialSpeed.Items.Add("57600"); cbxSerialSpeed.Items.Add("38400"); cbxSerialSpeed.Items.Add("28800"); cbxSerialSpeed.Items.Add("19200"); cbxSerialSpeed.Items.Add("14400"); cbxSerialSpeed.Items.Add("9600"); cbxSerialSpeed.Items.Add("4800"); cbxSerialSpeed.SelectedIndex = 0; cbxParityBits.Items.Add("Even"); cbxParityBits.Items.Add("Mark"); cbxParityBits.Items.Add("None"); cbxParityBits.Items.Add("Odd"); cbxParityBits.Items.Add("Space"); cbxParityBits.SelectedIndex = 2; cbxStopBits.Items.Add("None"); cbxStopBits.Items.Add("1"); cbxStopBits.Items.Add("1.5"); cbxStopBits.Items.Add("2"); cbxStopBits.SelectedIndex = 1; string[] ports = SerialPort.GetPortNames(); if (ports.Length > 0) { foreach (string port in ports) { cbxSerialPort.Items.Add(port); } cbxSerialPort.SelectedIndex = 0; // problem here when no prop is selected or plugged in InitPropellent(HandleFake, false, ""); SetGUIMode(0); } } private void buttonStart_Click(object sender, EventArgs e) { serialPort1.PortName = cbxSerialPort.SelectedItem.ToString(); serialPort1.BaudRate = Convert.ToInt32(cbxSerialSpeed.SelectedItem.ToString()); serialPort1.DataBits = Convert.ToInt32(tbxDataBits.Text); switch (cbxParityBits.SelectedItem.ToString()) { case "Even": serialPort1.Parity = Parity.Even; break; case "Mark": serialPort1.Parity = Parity.Mark; break; case "None": serialPort1.Parity = Parity.None; break; case "Odd": serialPort1.Parity = Parity.Odd; break; case "Space": serialPort1.Parity = Parity.Space; break; default: break; } switch (cbxStopBits.SelectedItem.ToString()) { case "None": serialPort1.StopBits = StopBits.None; break; case "1": serialPort1.StopBits = StopBits.One; break; case "1.5": serialPort1.StopBits = StopBits.OnePointFive; break; case "2": serialPort1.StopBits = StopBits.Two; break; default: break; } if (serialPort1.IsOpen == false) { int i = 0; for (i = 0; i < 11; i++) { Thread dBox = new Thread(new ParameterizedThreadStart(displayBox)); dBox.Start(i); Thread.Sleep(500); int iHandle = FindWindow(null, "Waiting for serial port..."); SendMessage(iHandle, WM_SYSCOMMAND, SC_CLOSE, 0); try { serialPort1.Open(); } catch (Exception ex) { } if (serialPort1.IsOpen) { break; } } if (i == 10) { MessageBox.Show("Port cannot be opened"); return; } } else { serialPort1.Open(); } if (serialPort1.IsOpen) { btnStart.Enabled = false; btnDetectPort.Enabled = false; btnStop.Enabled = true; tbxSerialData.ReadOnly = false; } } private void displayBox(object i) { MessageBox.Show("Waiting for serial port to become available, will try for another " + (10 - (Convert.ToInt32(i))) + " second(s)", "Waiting for serial port..."); } private void findWin() { MessageBox.Show(FindWindow(null, "Waiting ...").ToString()); int iHandle = FindWindow(null, "Waiting ..."); SendMessage(iHandle, WM_SYSCOMMAND, SC_CLOSE, 0); Thread.Sleep(1000); } private void buttonStop_Click(object sender, EventArgs e) { if (serialPort1.IsOpen) { serialPort1.Close(); btnStart.Enabled = true; btnDetectPort.Enabled = true; btnStop.Enabled = false; tbxSerialData.ReadOnly = true; } } private void textBox1_KeyPress(object sender, KeyPressEventArgs e) { if (!serialPort1.IsOpen) return; byte[] buff = new byte[1]; buff[0] = (byte)e.KeyChar; serialPort1.Write(buff, 0, 1); //// If the port is closed, don't try to send a character. //if (!serialPort1.IsOpen) return; //// If the port is Open, declare a char[] array with one element. //char[] buff = new char[1]; //// Load element 0 with the key character. //buff[0] = e.KeyChar; //// Send the one character buffer. //serialPort1.Write(buff, 0, 1); // Set the KeyPress event as handled so the character won't // display locally. If you want it to display, omit the next line. e.Handled = false; } private void DisplayText(object sender, EventArgs e) { RxString = Regex.Replace(RxString, @"\r", "\r\n", RegexOptions.None); tbxSerialData.AppendText(RxString); } private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e) { RxString = serialPort1.ReadExisting(); this.Invoke(new EventHandler(DisplayText)); } private Queue<byte> recievedData = new Queue<byte>(); private void button1_Click(object sender, EventArgs e) // button detect port { cbxSerialPort.Items.Clear(); string[] ports = SerialPort.GetPortNames(); foreach (string port in ports) { cbxSerialPort.Items.Add(port); cbxSerialPort.SelectedIndex = 0; serialPort1.PortName = port; serialPort1.BaudRate = 115200; serialPort1.Encoding = Encoding.ASCII; serialPort1.Open(); serialPort1.Close(); } var versionPtr = GetPropellerVersion(); string version = Marshal.PtrToStringAnsi(versionPtr); int delimiter = version.IndexOf(':'); if (delimiter > -1) { string comPort = version.Remove(delimiter - 1); string firmWare = version.Remove(0, delimiter + 2); tbxPropPortFound.Text = comPort; tbxPropChipVersion.Text = firmWare; int comPortIndex = cbxSerialPort.FindString(comPort); cbxSerialPort.SelectedIndex = comPortIndex; } } private void button2_Click(object sender, EventArgs e) { tbxSerialData.Text = ""; } private void serialPortWrite(string lineToWrite) { byte[] b1 = System.Text.Encoding.UTF8.GetBytes(lineToWrite); byte[] buff = new byte[b1.Length + 1]; int i = 0; foreach (byte byt in b1) { buff[i] = byt; i = i + 1; } buff[i] = (byte)13; serialPort1.Write(buff, 0, buff.Length); } private void button4_Click(object sender, EventArgs e) // Test Segment { SetGUIMode(3); var versionPtr = GetPropellerVersion(); string version = Marshal.PtrToStringAnsi(versionPtr); SetGUIMode(0); MessageBox.Show(version.ToString()); } private void textBox2_TextChanged(object sender, EventArgs e) { } private void btnCopySerialDataTextBox_Click(object sender, EventArgs e) { Clipboard.SetText(tbxSerialData.Text); } private void detectPropPort() { cbxSerialPort.Items.Clear(); string[] ports = SerialPort.GetPortNames(); foreach (string port in ports) { cbxSerialPort.Items.Add(port); cbxSerialPort.SelectedIndex = 0; serialPort1.PortName = port; serialPort1.BaudRate = 115200; serialPort1.Encoding = Encoding.ASCII; serialPort1.Open(); serialPort1.Close(); } var versionPtr = GetPropellerVersion(); string version = Marshal.PtrToStringAnsi(versionPtr); int delimiter = version.IndexOf(':'); string comPort = version.Remove(delimiter - 1); string firmWare = version.Remove(0, delimiter + 2); tbxPropPortFound.Text = comPort; tbxPropChipVersion.Text = firmWare; int comPortIndex = cbxSerialPort.FindString(comPort); cbxSerialPort.SelectedIndex = comPortIndex; } private void SimpleSerial_Load(object sender, EventArgs e) { detectPropPort(); } private void btnResetProp_Click(object sender, EventArgs e) { serialPortWrite("0"); } private void btnSend_Click(object sender, EventArgs e) { serialPortWrite(tbxSendData.Text); tbxSendData.Text = ""; } } }
