Need help with data parsing — Parallax Forums
turbosupraturbosupra Posts: 1,088
edited 2014-12-19 10:48 in Propeller 1
I'm trying to pass a long to a function and have it return the bytes. I thought this would be easy, but it has proven not to be. In a high level language I can set the return type when I declare a function, but I have no idea how to return an array in spin?
I've spent the past day trying to figure this out and seen a bunch of examples that were similar, but I cannot get any of them to work, they either display nonsense or the wrong thing?
Thanks for reading
    edited 2014-12-19 05:14
    You mean something like this?
    VAR
      byte  r[4]
    PUB main
      split(cnt, @r{0})
    PRI split(value, storage) : n
      repeat 4
        byte[storage++] := value.byte[n++]
    Note, you can't simply return a reference to local variables as they stop existing after returning. For this reason a reference to an array which is/remains valid in the caller's context is used.
  • turbosupraturbosupra Posts: 1,088
    edited 2014-12-19 05:28
    Hi Kuroneko,
    I tried to implement that into my code without success. The local variable lesson makes sense, I will have to remember that.
    I've attached my project with your code in it, what am I doing wrong?
    241978260
    196
    237
    109
    14
    edited 2014-12-19 05:33
    turbosupra wrote: »
    How do you define success? I admit it's untested code (at work right now) but all you get from it is a byte split system counter (I could have used split(exampleValue, @r{0}) instead).
    From your example I can see that the value to be split was 242085316 (14 << 24 | 109 << 16 | 237 << 8 | 196) which makes sense since cnt has advanced from its original value (241978260).
    edited 2014-12-19 05:44
    I believe your code works, I came across a similar example in my searching that you provided to someone else (in 2012 I think).
    Success is my ability to implement it and understand it, of which I haven't been successful at yet. I thought I had implemented it wrong, but based on your response I implemented it right and just don't understand. I'll keep working at it.
  • PaulPaul Posts: 263
    edited 2014-12-19 05:48
    [serious] I'm looking at that @r{0} and scratching my head. Is this a thing now? [/serious]
    Granted I've missed quite a few memos over the years.
    Paul
    edited 2014-12-19 05:50
    I have forgotten what that means. I've also forgotten what the : in a function is for? Maybe the same thing as a | ?
    Paul wrote: »
    Paul
    edited 2014-12-19 05:53
    Paul wrote: »
    The intention is to pass the address of the first element of the byte array named r. Since the first index is 0 that would be @r[0]. For index 0 the actual index is optional (in SPIN array[0] is the same as array but the latter is smaller). To remind me that it's still an array I use a comment which looks like an indexed access modifier, i.e. @r{0}.
    The colon after a function name separates the return parameter (by default result but it can be aliased, n in my example). It is also the only local variable which is cleared (important for the loop).
    edited 2014-12-19 06:06
    Okay, it makes sense as far as documenting what you are doing for your future self and others to understand "r" is an array. Very clever.
    (sorry for the thread hijack)
    edited 2014-12-19 06:09
    Thank you for that format explanation Kuroneko.
    I also figured out how the function works and why it works that way. It works with the value I would like to send to it. If I wanted to split the value literally, is there an easy way to do that? For example if I wanted to split 242085316 into 2420 and 85316, is a string parsing function needed? I was trying to use a string parsing function originally.
    split(242085316, @r{0})
    ' 242085316 in binary is 1110 01101101 11101101 11000100
    11000100
    11101101
    01101101
    00001110
    196
    237
    109
    14
    edited 2014-12-19 06:57
    turbosupra wrote: »
    You could use string manipulation for this but you could also divide by 100000 to get the top part (2420) and variable // 100000 to get the lower part (85316).
  • JonnyMacJonnyMac Posts: 9,834
    edited 2014-12-19 07:10
    In Spin you have direct access to the bytes in a word or long -- like this
    myByteVar := someLongVar.byte[n]
    ... where n is the byte number, 0 to 3 for longs, 0 or 1 for words.
    If 242085316 is a number you can extract portions with simple math
    hi := longVar / 100_000
      lo := longVar // 100_000
    Ok, thank you gentlemen
