Issue with 2 touch area of UOLED 4D system — Parallax Forums
JChrisJChris Posts: 58
edited 2014-12-20 14:17 in Propeller 1
I use UOLED 4D system that is the 32PTU.
I am trying to create a menu. When I create only one touch area, it works but when I create two touch areas, it doesn't work.
The program runs but there are two touch areas that don't work fine
If anyone has a hint, I would appreciate
My program is the following:
[Code]
* AUTO-RECOVER NOTICE: This file was automatically recovered from an earlier Propeller Tool session. *
* ORIGINAL FOLDER: D:\parallax\ *
* TIME AUTO-SAVED: over 1 day ago (14/08/2014 00:21:48) *
* OPTIONS: 1) RESTORE THIS FILE by deleting these comments and selecting File -> Save. *
* The existing file in the original folder will be replaced by this one. *
* -- OR -- *
* 2) IGNORE THIS FILE by closing it without saving. *
* This file will be discarded and the original will be left intact. *
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5000000
rxpin = 3
txpin = 4
reset = 5
OLEDBaud = 115200
obj
LED : "uLCD(SK)-32PTU_v2.0"
var 'Used ONLY for DEMO
long Random,X[4],Y[4],Angle[4],OldX[4],OldY[4],C[8], stack1[50], stack2[50],Touch1, OldTouc1,TouchCount1,Flag1,i
word X1,X2,X3,Y1,Y2,Y3
PUB main
LED.start(rxpin, txpin, reset, OLEDBaud) ''Starts uOLED display
LED.touch_Set(0)
RentrerEnContact
PUB RentrerEnContact
LED.touch_DetectRegion(8,18,160,94)
LED.gfx_Rectangle(8,18,160,53,LED.RGB(255,255,0))
LED.gfx_Button(1,10,20,LED.RGB(128,128,128),LED.RGB(255,255,255),2,1,2,string("Rentrer en contact"))
' LED.touch_DetectRegion(8,58,151,94)
' LED.gfx_Rectangle(8,58,151,94,LED.RGB(255,255,0))
' LED.gfx_Button(1,10,60,LED.RGB(128,128,128),LED.RGB(255,255,255),2,1,2,string("Trouver personne"))
LED.txt_BGColor(LED.RGB(0,0,0)) ''Set FG/BG color text for PRESSED RELEASED
' txt_FGColor(color)
LED.txt_FGColor(LED.RGB(64,255,64))
i := 0
repeat
Touch1 := LED.touch_Get(0) ''<-Touch Detect 0-Screen STATUS
X1 := LED.touch_Get(1) ''<-Touch Detect 1-X coordinate
Y1 := LED.touch_Get(2) ''<-Touch Detect 2-Y coordinate
if (Touch1 == 1)
if ((X1>=8 AND X1<= 160) AND (Y1>=18 AND Y1<=53 ))
if Touch1 <> OldTouc1
LED.ClearScreen
Case Touch1
0 : LED.txt_MoveCursor(11,1)
'LED._putStr(string("NO TOUCH",10)) '' Not used in DEMO
1 : LED.txt_MoveCursor(11,1)
coucou
'telephone
2 : LED.txt_MoveCursor(11,1) '' to trap ONLY the window of interest
if Flag1 == 1
Flag1 := 0
LED._putStr(string("RELEASED",10))
TouchCount1 := 50 '' Set Extinguish after release timeout
' 3 : LED.txt_MoveCursor(11,1)
' LED._putStr(string("MOVING ",10)) '' Not used in DEMO
' OldTouch1 := Touch1
if TouchCount1>0 '' Extinguish after release
TouchCount1--
if TouchCount1 == 0
LED._putStr(string(" ",10))
PUB coucou | Touch2, OldTouch2, Flag2, TouchCount2
LED._putStr(string("Dis bijour a rorodolf",10))
' LED.touch_Set(0)
LED.touch_DetectRegion(8,18,160,53)
LED.gfx_Button(1,10,20,LED.RGB(128,128,128),LED.RGB(255,255,255),2,1,2,string("coucou"))
repeat
if (Touch1 == 1)
LED.ClearScreen
Case Touch1
LED._putStr(string("Pressed",10))
bonjour
if Flag1 == 1
Flag1 := 0
TouchCount1--
if TouchCount1 == 0
PUB bonjour | Touch3, OldTouch3, Flag3, TouchCount3, Touch2, OldTouch2, Flag2, TouchCount2
LED._putStr(string("Dis bonjour a bibi",10))
' LED.touch_Set(2)
LED.gfx_Button(1,10,20,LED.RGB(128,128,128),LED.RGB(255,255,255),2,1,2,string("au revoir"))
LED.gfx_Button(1,10,60,LED.RGB(128,128,128),LED.RGB(255,255,255),2,1,2,string("boujour"))
repeat
Touch3 := LED.touch_Get(0) ''<-Touch Detect 0-Screen STATUS
X3 := LED.touch_Get(1) ''<-Touch Detect 1-X coordinate
Y3 := LED.touch_Get(2) ''<-Touch Detect 2-Y coordinate
Touch2 := LED.touch_Get(0) ''<-Touch Detect 0-Screen STATUS
X2 := LED.touch_Get(1) ''<-Touch Detect 1-X coordinate
Y2 := LED.touch_Get(2)
if (Touch3 == 1)
if ((X3>=8 AND X3<= 151) AND (Y3>=53 AND Y3<=94 ))
if Touch3 <> OldTouch3
Case Touch3
LED._putStr(string("pas touch
  • OldFartRadiomanOldFartRadioman Posts: 30
    edited 2014-12-18 09:02
    Little bit of a mystery here, I seem to be having trouble finding uLCD(SK)-32PTU_v2.0.
  • JChrisJChris Posts: 58
    edited 2014-12-18 14:36
    It used to be there
    http://obex.parallax.com/object/722
    Apparently it has been removed by Parallax for an unknown reason...
    Might still be somewhere on the forum.
    Here is the library (uLCD(SK)-32PTU_v2.0) that I managed to download when it was still available on the parallax site.
    uLCD(SK)-32PTU_v2.0.spin
    edited 2014-12-18 22:56
    JChris wrote: »
    Not sure if (or how) related or not but you should review your program structure first. You're basically calling one method from within another. Method calls expect to return to the calling point so if you don't (circular calls) you'll eventually run out of stack.
  • avsa242avsa242 Posts: 480
    Just a cursory look, I'm wondering if the use of the assignment form of "Is Greater-than (>=)/Is Less-than (<=)" operators was really intended, or if "Is Greater-than or equal to (=>)/Is Less-than or equal to (=<)" was what was really meant in the sections that check for a range in X and Y.
    Also, the last instance,
          if ((X2>=8 AND X2<= 160) AND (Y2>=18 AND Y2<53 ))
    is missing an equals sign = from the "Y2<53"
