Easy VR + PIC Board
My university project is to control a 2WD Robot using Voice Recognition
SO i got the EASY VR Module but it is used generally with Arduino Uno
I am using a PIC Board
Any one have any experience with this kind of Combination ?
If your PIC has an UART, it should work fine with the EasyVR. I think the 9600 baud is slow enough, you could get by with a software UART though it would be nice to have a FIFO buffer.
There was some discussion about the EasyVR in this thread. Hopefully there is information in the thread which will make it easier to see what it takes to interface with the module.
So can anyone help me to write this library
Generally people on the forum are willing to answer questions and possibly take a look at a program someone else is working on but it's very uncommon for someone to write software for someone else for free.
I've written some example code to use the EasyVR on the Propeller but this was because I wanted to use the EasyVR with the Propeller myself. The trick will be finding someone who also wants to use the EasyVR with a PIC but I doubt there are many people on the Parallax forums who are planning to do this. The Propeller, SX and the Basic Stamp tend to be microcontrollers used around here.
Have you asked in any of the PIC forums?
Edit: As I think about this a bit more, I'm not sure how much a "library" would really be useful. The EasyVR interface is pretty simple. Most of the work will be in writing code to activate the correct word groups and branching the program in the correct paths. These aspects will be very dependent on the type of program you're writing and I don't see a library as being much of a help.
Of course seeing some examples using he PIC would helpful but doesn't the PIC use C? I'd think many of the Arduino examples would be applicable to the PIC.
I did see this post but it doesn't look like the code worked.
I found it really helpful to understand how the EasyVR worked by watching the communication between the PC GUI program and the EasyVR. I did this by setting up a bridge program to monitor the data exchange and send the exchange to a terminal window.
This post has details about what I saw in this exchange.
Sorry I don't know much about PIC microcontrollers but I'll try to answer any questions about the EasyVR I can.
Hi Leon,
He will of course he will have to write the software himself. This doesn't mean he has to write every low level driver. Nor does it mean it wouldn't be helpful to find some examples with using the PIC with an EasyVR.
