Need help with my final project in engineering — Parallax Forums
ChaseH19ChaseH19 Posts: 1
edited 2014-12-09 16:05 in BASIC Stamp
I'm using a Parallax Board of Education (2000-2006) and need to control two servos with two potentiometers. The potentiometers I need to use aren't the ones the board comes with, they look like the one attached below...
I understand how to control a single servo with one potentiometer (Chapter 5 Activity 4 in "What's a Micro-controller" book by Parallax)
I need help with how to properly wire the board and the code for it. I have found other people's posts asking for similar things but not exactly what I need.
Thanks Guys!
259 x 194 - 6K
  • JonnyMacJonnyMac Posts: 9,829
    edited 2014-12-08 12:19
    Most participants frown on youngsters asking for help with their homework.
    If you can control one servo, you can control two. I won't give you code, but will suggest a strategy
    1) Read 1st pot
    2) Convert pot reading to compatible servo value
    3) Generate pulse to first servo
    4) Read 2nd pot
    5) Convert pot reading to compatible servo value
    6) Generate pulse to second servo
    7) Wait about 17 milliseconds
    8) Back to Step #1
    With the pulses and 17 milliseconds delay, you get about 20 milliseconds between updates (this is fine -- doesn't have to be exactly 20ms).
  • mklrobomklrobo Posts: 420
    edited 2014-12-08 14:03
    Alot of good code projects are in the OBEX section of this forum.(upper top right).
    It makes a difference what you are writing code in; Spin or C. The code snippets
    in the OBEX are mostly Spin. I am using a book on Spin, "Programming the
    propeller with Spin; a beginner's guide to parallal processing." Gives alot
    of code and schematics on what you are looking for. I am writing a program
    that requires measuring pulses, which involved the counters, A & B. In the
    code that I have seen, counters are used in controlling the counters too.
    Good luck! :)
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-12-08 14:11
    I think he is using the Stamp BOE, since this is the Stamp Forum.
    mklrobo wrote: »
    Dude - the OP is using a Stamp, not a Propeller.
    :smile:
    (...Andy beat me to it!)
    edited 2014-12-08 15:58
    JonnyMac wrote: »
    No frowning from this participant! Paypal $1000 to me and I'll send you all the code you desire. :)
    JK, you wouldn't want very much help on your final in Engineering. Treasure the challenge!
    edited 2014-12-09 05:25
    Oops! :( Alot of help I am with the basic stamp! Sorry about that.
    (You would enjoy the propeller too!)
  • GenetixGenetix Posts: 1,777
    The center pin of your pot should be the Wiper and the left pin should be terminal A though I would verify this with a multimeter.
    Place your meter in the 20K range and you should see the value go from a low value to around 10K as you turn the pot clockwise, assuming your pots are also 10K.
