simpleIDE 1.0 RC1 ? — Parallax Forums
simpleIDE 1.0 RC1 ?
RsadeikaRsadeika Posts: 3,901
edited 2014-12-07 21:03 in Propeller 1
I just decided to try my C3 and DNA-RTC boards for XMM mode(s), on both boards I get an error: failed to connect to helper. I also thought that, using COGs in XMM mode was going to be added, it looks like no XMM mode(s) is working with the boards.
Ray
    edited 2014-12-07 14:07
    Rsadeika wrote: »
    Ray
    The multi-COG XMM mode is only supported in the propgcc default branch. The release_1_0 branch that is included with SimpleIDE does not support it. Also, there seems to be some problem with propeller-load in the SimpleIDE RC1 release. Steve mentioned this in another thread. I'll try checking out release_1_0 tonight and to see if propeller-load has a similar problem on the Mac. I don't use Windows so I can't easily test it in that environment.
    I checked out the release_1_0 version of propgcc and built propeller-load for the Macintosh and it seems to work fine. This problem must be restricted to the Windows version.
