Noob trying to power the Propeller Activity Board with a battery pack
bubby9534
I have a project where I'm using my Propeller to override a hobby R/C car's control unit. I want to use the car's power source to power the Propeller. The power source in the car is 6V 2000mA.
I know the voltage should be 6-9V to properly run the Propeller Activity Board, but does the amperage matter? 2000mA seems like a lot.
What is more likely is interference over the power lines from the car's motor. If you find this, connect the 6v using a series inductor.
Keep us informed with your progress here. If you have any questions, don't hesitate to ask. There are plenty of knowledgeable people here willing to help.
The amperage from the battery is what it can supply. The amperage that the Activity Board will need depends on the components on board.
Don't worry about to battery's capacity to deliver 2000ma, the Activity board will only use what it needs. You will not over drive it.
Edit: Ray types faster than me.
I suppose I should provide some background. I have a Traxxas Slash R/C car and want to automate it by replacing the radio reciever with my Propeller board. Since the speed control and servo on the car have standard three-pin connectors that plug into the three-pin connectors on the top of the board, it'll be easy to interface with the car.
One issue I'm encountering is that when I attempt to control the servo, it won't respond at all like I expect when using the servo control library (I'm using C). I wonder if it's because it doesn't have enough power or is controlled differently.
If I change the 3-pin header toggles from 5V to Vin, the servo I plug into the header will get as much power possible from the power input to the board, correct?
Careful, depending on the Servo too much over 6 volts will cause the magic smoke to pour out.
I'll post this project with photos eventually so I can demonstrate what I'm trying to do.
You might try removing the load (mechanical) on the servo and test to see that the servo is working correctly. You need to get this far first up.
There are some servo demos in the obex.
My overall goal is to replace the receiver unit with the Propeller. What I've accomplished so far is powering the Propeller board with the 6V Regulated Cable from the motor controller, and I managed to get the servo to make incoherent movements. At this point I just need to figure out how exactly the receiver interfaces with the servo and the motor controller, and get the Propeller to mimic that so that it can control those things autonomously.
http://obex.parallax.com/search/RC
One that i have used in the past is:
http://obex.parallax.com/object/505
