Problem with PAM-7Q GPS Module
Hello ,
I downloaded the example code for the Pam-7Q GPS , and after running it with terminal I got "GPS Fix : Not Valid " . Any help will be appreciated
Welcome to the forums!
The GPS has to have a good field of view for satellites. This means it can not be inside a building.
Where are you trying to run the GPS module from.?
I try the GPS inside and outside the building .
Publison's question about having a picture of your setup is an important one. The old adage "a picture is worth a thousand words" really applies here because it let's us see just how you have the GPS module wired up. From there, we can give you relevant suggestions. As much extra detail you can give, the better our suggestions will be.
Thank you,
Daniel
The PAM-7Q has a satellite lock LED, the same LED that doubles as a power indicator. According to the docs, if that's blinking, it means at least one satellite is in lock. So if you get a blinking LED, but no valid values coming through, then the likely culprit is a wiring error. A photo of your connection would help, but you can also determine at least some things like whether the LED is on at all.
The problem with assisting on forums is that no one knows your level of expertise, and what you've already tried. It does help if you go through the steps you've already taken to troubleshoot. As noted by the others, a clear photo is also a nice bonus.
Thank You all for your quick help and Support .
Good News!
Feel free to ask more questions.
