Help with Bluetooth LE — Parallax Forums
mynet43mynet43 Posts: 644
edited 2014-12-03 08:52 in Propeller 1
I'm building a board that has a Propeller, an accelerometer and Bluetooth LE.
Can someone recommend a BLE module that will easily support serial communication from the Propeller?
I plan to use this to communicate to an iOS device, using TechBASIC for the iOS.
Thank you for your help and support.
Jim
  • dgatelydgately Posts: 1,647
    I had started a thread on using a Bluetooth LE device to communicate between an iPhone or iPad to an Activity Bot. I basically, had a simple robot controller iOS app that was a wireless remote for moving the bot in different directions, turned on/off 2 LEDs and set off a piezo buzzer on the bot. I used a Bluetooth LE (4.0) module that I had soldered to a recovered older Bluetooth 2.0 module with some slight changes. I've kinda put that project "to bed" while working on XBee S6B wireless solution, but that thread should give you some ideas...
    http://forums.parallax.com/showthread.php/153249-iOS-to-Propeller-programming-proof-of-concept
    dgately
