PCB Design Software — Parallax Forums
PCB Design Software
David BetzDavid Betz Posts: 14,530
edited 2014-12-01 17:24 in General Discussion
I seem to remember that Parallax was standardizing on some PCB layout package. Can someone remind me of which one they are using? I'd like to try to design a simple PCB.
    edited 2014-11-30 15:57
    David Betz wrote: »
    Never mind. I did a quick search and found that the Parallax recommended layout software is DipTrace.
    edited 2014-11-30 16:23
    Ummm... Maybe the PC version of this software is stable but I just tried installing the Mac version and it crashed my Mac so hard I had to force power it off to recover. It doesn't seem that the Mac version is ready for prime time.
    edited 2014-12-01 03:59
    David Betz wrote: »
    That's too bad. I hope you have a way of using the PC version.
    I was trying to learn to use Eagle when Parallax mentioned they were using Diptrace. I was reluctant to switch myself since I had already put a lot of effort into trying to learn to use Eagle. I'm very glad I switched to Diptrace. It didn't take long for my ability in using Diptrace to surpass my ability to use Eagle.
    A lot of PCB fab houses will allow one to submit the Eagle files but not Diptrace files. This isn't really a big deal since it's really easy to export a design to gerber and drill files. I've submitted designs to several different fab houses using these exported files (zipped together).
    I've posted a couple examples of these exported files to the forum. One example is my version of a 16 LED ring and another example (my single WS2812B board) is attached to this post.
    I like OSH Park for small boards. OSH Park sells their boards in sets of three. There are a bunch of less expensive fab houses which sell their boards in sets of ten. If your board is larger than a few square inches, it's probably less expensive to use one of these other fab houses.
    I've used ITead Studio and Dirty PCBs. I like the color choices offered by Dirty PCBs.
    I haven't decided if I like their yellow PCBs yet.
    They also make nice stainless steel stencils.
    All the fab houses I mentioned used the zipped up files I exported from Diptrace using the default settings. It was surprisingly easy to submit these designs so don't let the requirement to export files sway you from using Diptrace.
    761 x 622 - 330K
    edited 2014-12-01 07:46
    Duane,
    Do you panalize you PCB's, or let the Fab House do it?
    Jim
    edited 2014-12-01 09:56
    Duane Degn wrote: »
    Thanks for your comments. I installed Windows 7 in a VirtualBox VM on my MacBook Pro and installed the free version of DipTrace. After playing with it for about five minutes I can see it will be easier for me to learn than Eagle.
    edited 2014-12-01 10:08
    Publison wrote: »
    Duane,
    Jim
    Jim, I hope you don't mind, I replied to your question in my "NonaProp" thread.
    edited 2014-12-01 10:13
    Duane Degn wrote: »
    What does it mean to "panelize" a PCB? I assume this is when you place multiple copies of the same design on a board and then provide scoring so the board can be broken into separate units? is this a service that PCB houses provide, the scoring I mean?
  • JonnyMacJonnyMac Posts: 9,555
    edited 2014-12-01 10:20
    I used DipTrace first but installed Eagle because there are so many Open Source files that use it. I agree with you, though, Dip Trace is easier.
    edited 2014-12-01 10:23
    David Betz wrote: »
    I assume so. As I mention in the other thread, I've trying to do the scoring myself.
    I've read forum posts stating FAB houses offer several different options on how a board is panelized.
    I know I didn't want all the boards scored. You never know when you might need nine Propellers on a single PCB? (right?)
    edited 2014-12-01 10:40
    Are you happy with the quality of the PCBs, Duane? I find it odd that their banner states: "No bull, just crappy PCBs"
    edited 2014-12-01 10:56
    JonnyMac wrote: »
    Maybe after I become proficient with DipTrace, I can try Eagle again. Need to crawl before I can walk or run!
    edited 2014-12-01 11:07
    JonnyMac wrote: »
    I don't find their name or slogans confidence boosters but I think the quality is great. I paid $15 extra to have the ENIG finish and I also ordered stencils.
    I'm far from an expert but with the added gold plating, the quality seems to match OSH Park. The yellow is kind of growing on me and I think I may end up liking it. The yellow and gold together look nice though come to think of it, every color probably looks good next to gold.
    I don't have any experience with stencils to offer as a comparison but the stencils also seem nice.
    I'm minutes away from my first solder paste stencil attempt.
    IIRC, the shipping was a bit more than some of the other fab houses but once the boards were done, I think they arrived pretty quickly (though now I'm not sure). So far, I plan to use them again.
    Thanks for the feedback and the tips on other sources. I tend to use GoldPhoenixPCB, but can be a little expensive for personal prototypes.
