Cannot make the Wheel_Controller.spin to work with FullDuplexSerial — Parallax Forums
VovikVovik Posts: 4
edited 2014-11-30 08:56 in Robotics
I am trying to use the Motor Mount and Wheel Kit (#27971) with Position Controllers (#29319).
Trying to use the object I have got from here http://obex.parallax.com/object/663
The problem is when I am just trying to add a serial terminal to the WC_Test_Harness.spin to be able to query position of a wheel and see in terminal the wheel does not rotate in spite I have just only add FullDuplexSerial to the OBJ block and add a line to start it. Without those 2 lines wheel rotates as programmed.
The test harness stops working as soon as I try to add this two lines to the example WC_Test_Harness.spin (the_____ pst: "FullDuplexSerial" _____ to OBJ block and ____pst.Start(31, 30, 0, 115200)_____ to the PUB MAIN)
OBJ
WCtrl: "Wheel_Controller"
PUB MAIN | success
Basically once those 2 lines with pst.... added to the test harness it does not rotate wheels at WCtrl.spin_turn(WCtrl#LEFT_TURN, 360) or any other WCtrl commands.
Does anybody knows what could be a problem?
By the way the similar situation happens when I am trying to add a Ping.spin object ( the one from the "Ping Demo")
Does anybody know
  • ElectrodudeElectrodude Posts: 1,687
    edited 2014-11-29 10:47
    How many other cogs are you using? I suspect you have run out of cogs.
    If not, can you please post all of your code?
  • VovikVovik Posts: 4
    Here it is the code. Basically it is just the code from http://obex.parallax.com/object/663 with only 2 lines added.
    When I have add the line "pst: "FullDuplexSerial" to the object block all still works ok...
    But when in addition I have add "pst.Start(31, 30, 0, 115200)" to the PUB MAIN it behaves like this:
    1. upon Run / Compile it compiles successfuly
    2. then it runs and light the RED LED (as well as expected)
    3. Them when I push the button it blionks the RED LED (while the expected result it should light the GREEN LED and move wheels).
    The WC_Test_Harness.spin code is here (as well I attach the both files of the project for your convenience).
    '' WC_TestHarness.spin
    '' This test harness is designed to exercise the Wheel Controller object.
    '' The cart uses a Propeller Education Kit board with:
    ''      1. Push button on pin zero
    ''      2. Red LED on pin 2
    ''      3. Green LED on pin 3
    ''      2. Position Controllers on pin 27
    CON
      _clkmode = xtal1 + pll16x      ' Crystal feedback & PLL multiplier
      _xinfreq = 5_000_000           ' 5 MHz crystal
      START_BUTTON = 8
      RED_LED = 9
      GREEN_LED = 10
    VAR
      ' Global Variables:
      long WC_Stat                  ' Wheel Controller Status
      word RobotSpeed
      long loop_cnt
      long FreezeCount
      long LastStatus
      long Delta
      long Val
    OBJ
    '' Main Entry
    PUB MAIN | success
      dira~
      outa~
      dira[RED_LED..GREEN_LED]~~    ' Set LED pins to output
      FreezeCount := 0
      LastStatus := 0
      waitcnt(clkfreq + cnt)
      success := WCtrl.open(0)     ' Initialize Wheel Controller
      if success == FALSE
        repeat
          outa[RED_LED] := 1
          waitcnt(clkfreq/2 + cnt)
          outa[RED_LED] := 0
      pst.Start(31, 30, 0, 115200)                        'Start serial communication, and wait 2 s for Parallax Serial Terminal connection.
      ' Loop forever.
      repeat
        ' Turn on the Red LED to indicate that we are stopped.
        outa[RED_LED] := 1
        outa[GREEN_LED] := 0
        ' Wait for the Start Button to be pressed.
        repeat
          waitcnt(clkfreq/4 + cnt)
          if ina[START_BUTTON]
            if WC_Stat == 0
              ' This is the first time the Start Button has been pressed
              ' so the Wheel Controller is started.
              WCtrl.start
              WC_Stat := WCtrl.get_Status
            QUIT
          Check_Status
        ' Turn on Green LED to indicate we are moving.
        outa[RED_LED] := 0
        outa[GREEN_LED] := 1
    '' The following test will command each wheel to go 200 encode units.
        WCtrl.travel_units(200, WCtrl#RIGHT_WHEEL)
        WaitForArrival
        WCtrl.travel_units(200, WCtrl#LEFT_WHEEL)
        WaitForArrival
    '' The following test will travel in a five foot square with a 360 degree
    '' right turn at the start and a 270 degree left turn at the end:
        WCtrl.set_WheelSpeed(WCtrl#ALL_WHEELS, 176) ' 2 mile/hour
        WaitForArrival
        WCtrl.go_Distance(60, WCtrl#FORWARD)
        WaitForArrival
        WCtrl.spin_turn(WCtrl#RIGHT_TURN, 90)
        WaitForArrival
        WaitForArrival
        WaitForArrival
        WaitForArrival
        WaitForArrival
        WaitForArrival
        WCtrl.spin_turn(WCtrl#LEFT_TURN, 270)
        WaitForArrival
    '' The following test will:
    ''    1. Set speed to 100 ft/min
    ''    2. Go forward
    ''    3. Turn to the right until the right wheel stops
    ''    4. Turn back to the left until the left wheel stops
    ''    5. Stop all wheels
    ''    6. Wait for all wheels to come to a complete stop
        WCtrl.set_WheelSpeed(WCtrl#ALL_WHEELS, 100)  'Set speed to 100 ft/min
        Delta := 10
        Val := 0
        WCtrl.go_Distance(2000, WCtrl#FORWARD)  'Go forward for long distance
        repeat
          Val += Delta
          WCtrl.turn(Val)
          if Val => 100
            Delta := -10
          elseif Val =< -100
            quit
        WCtrl.stop
        WaitForArrival
    ''    1. travel forward for 4 seconds
    ''    2. travel backward for 4 seconds
    ''    3. spin turn 360 degrees to the left
        loop_cnt := 0
        repeat
          loop_cnt++
          if loop_cnt == 4
            quit
        WCtrl.stop
        WaitForArrival
        loop_cnt := 0
        WCtrl.go_Distance(2000, WCtrl#REVERSE)
        repeat
          loop_cnt++
          if loop_cnt == 4
            quit
        WCtrl.stop
        WaitForArrival
        WaitForArrival
    ''     1. set speed to one mile per hour
    ''     2. start forward
    ''     3. at 2 seconds increase speed to two miles per hour
    ''     4. at 4 seconds increase speed to three miles per hour
    ''     5. at 6 seconds decrease speed to two miles per hour
    ''     6. at 8 seconds decrease speed to one mile per hour
    ''     3. at 10 seconds stop
        WCtrl.set_WheelSpeed(WCtrl#ALL_WHEELS, 88)
        loop_cnt := 0
        repeat
          loop_cnt++
          if loop_cnt == 2
          elseif loop_cnt == 4
            WCtrl.set_WheelSpeed(WCtrl#ALL_WHEELS, 264)
          elseif loop_cnt == 6
          elseif loop_cnt == 8
          elseif loop_cnt == 10
            quit
        WCtrl.stop
        WaitForArrival
    '' The following test will move the cart in a arc to the right and then to
    '' the left.
        WCtrl.set_WheelSpeed(WCtrl#ALL_WHEELS, 0)
        WCtrl.turn(0)
        WCtrl.turn(20)
        WaitForArrival
        WCtrl.turn(-20)
        WaitForArrival
        WCtrl.turn(0)
    '' The following test will test the throttle during a straight run:
    ''    1. Set speed to zero
    ''    2. Go forward
    ''    3. Throttle up to 120 percent
    ''    4. Stop all wheels
    ''    5. Wait for all wheels to come to a complete stop
        Delta := 5
        Val := 0
        repeat
          Val += delta
          WCtrl.throttle(val)
          if Val => 120
            quit
        WCtrl.stop
        WaitForArrival
    '' The following test will test the throttle during a turn:
    ''    2. Set turn bias to 25 percent
    ''    2. Go forward
        Delta := 5
        Val := 0
        WCtrl.turn(25)
        repeat
          Val += Delta
          WCtrl.throttle(Val)
          if Val => 120
            quit
        WCtrl.stop
        WaitForArrival
    '' This method will wait for the arrival flag to get set.  It will periodically
    '' ckeck the Wheel Controller Cog to determine if it has failed.
    PRI WaitForArrival
      repeat
        ' Wait or do other processing.
        if WCtrl.arrival_check <> 0
          quit
        Check_Status
    '' Check Status Method -- this method will determine if the Wheel Controller Cog
    '' has stopped.  If it has stopped then the Red LED is flashed and any further
    '' processing suspended.  This will most likely be caused by a low battery
    '' condition.  A user may not want to stop here but instead go on to some sort of
    '' recovery processing.
    '' Note that calling the Wheel Controller 'start' method will reset it.
    PRI Check_Status | r1
      r1 := WCtrl.get_Status
      if r1 == 0
        return                      ' Wheel Controller not started yet
      if r1 == LastStatus
        FreezeCount++
        if FreezeCount == 6
        ' Wheel Controller Failure
          outa[RED_LED] := 1
          repeat
            outa[RED_LED] := 1
            outa[RED_LED] := 0
      else
        FreezeCount := 0
      LastStatus := r1
