toggle output of propeller with one input switch
I started to write a program in C using simpleIDE with different in- and outputs.
I define the inputs as integers like 'int button1=input(12);" and setting the output 17 with "high(17);"
I would like to have the same input toggling the output so that it comes on with the first push action and goes off with the following push-action.
Can anyone give me an example of how to do this??
#include "simpletools.h" bool buttonStates[32]; // startup zero bool buttonPressed[32]; // startup zero bool buttonReleased[32]; // startup zero void debounceButtons() { static int buttonShifts[32]; // startup zero for(int i = 0; i < 32; i++) { buttonShifts = (buttonShifts << get_state(i)); // Seen 32 one samples and was previously low if( (!(~buttonShifts)) && (!buttonStates[i])) { buttonStates[i] = true; if(!buttonPressed[i)] { buttonPressed[i] = true; } } // Seen 32 zero samples and was previously high if( (!buttonShifts) && buttonStates[i]) { buttonStates[i] = false; if(!buttonReleased[i]) { buttonReleased[i] = true; } } } } void getButtonState(int pin) { return buttonStates[pin & 0x1F]; } void getButtonPressed(int pin) // returns true once per button press { if(buttonPressed[pin & 0x1F]) { buttonPressed[pin & 0x1F] = false; return true; } return false; } void getButtonReleased(int pin) // returns true once per button release { if(buttonReleased[pin & 0x1F]) { buttonReleased[pin & 0x1F] = false; return true; } return false; } int main() { low(17); for(;;) { waitcnt((CLKFREQ/1000)+CNT); debounceButtons(); if(getButtonPressed(12)) { toggle(17); } } }
