Canbus
Hi. I am looking for some help on a canbus project I am working on. All I would like to do is display my vehicle RPM on a lcd display. I am using the MCP2515 and the MPC2550 transceiver.
Nothing fancy. The code I have written just writes a $C9 to my display. Does not change as rpm's are increased. I believe I am reading the right buffer (RXB0). I am also using PID $0C (engine RPM).
Here is my sample program. Any help would be greatly appreciated. I've tried my best.
' {$STAMP BS2}
'All of these Mode changes occur by writing to Regsister $0F
'Same as a Reset Command, but written to CANCNTL register
'[ REQOP MODES ]
CONFIG CON $80 '%1000_0000
LISTEN CON $60 '%0110_0000
LOOP_BACK CON $40 '%0100_0000
SLEEPING CON $20 '%0010_0000
NORMAL CON $00 '%0000_0000
MASK CON $E0 '%1110_0000
'[ SPI Commands ]
SPI_RESET CON $C0 '%1100_0000
SPI_READ CON $03 '%0000_0011
SPI_WRITE CON $02 '%0000_0010
SPI_RD_RXBUF CON $90 '%1001_0000
SPI_LD_TXBUF CON $40 '%0100_0000
SPI_RTS CON $80 '%1000_0000
SPI_RTS_TXB0 CON $81 '%1000_0001
SPI_RTS_TXB1 CON $82 '%1000_0010
SPI_RTS_TXB2 CON $84 '%1000_0100
SPI_RD_STATUS CON $A0 '%1010_0000
SPI_RX_STATUS CON $B0 '%1011_0000
SPI_BIT_MOD CON $05 '%0000_0101
'************************ VARIABLES ***************************
CAN_DATA VAR Byte
'****************** RESET_CAN / INITIALIZE ********************
CAN_START:
LOW 11 'CS SHIFTOUT = PIN,CLK,MSBFIRST
SHIFTOUT 9, 10, 1, [SPI_RESET]
HIGH 11
PAUSE 10
'LOW 11 'CS
'SHIFTOUT 9, 10, 1, [SPI_WRITE,$0F,CONFIG] 'RESET DOES SAME
'HIGH 11
'PAUSE 10
' V1
LOW 11 'CS ' 250kB 500kB 250kB
SHIFTOUT 9, 10, 1, [SPI_WRITE,$28,$04] 'CNF3_REG $04 $04 [$02]
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$29,$E4] 'CNF2_REG $E4 $E4 [$90]
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$2A,$01] 'CNF1_REG $01 $00 [$03]
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$30,$03] 'TXB0CTRL_REG
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$40,$03] 'TXB1CTRL_REG
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$50,$03] 'TXB2CTRL_REG
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$0D,$00] 'TXRTSCTRL_REG
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$2B,$81] 'CANINTE_REG
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$2C,$00] 'CANINTF_REG
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$2C,$FF] 'BFPCTRL_REG
HIGH 11
PAUSE 10
'********************* RXB0 MASK/FILTERS **********************
LOW 11 'V1 V2
SHIFTOUT 9, 10, 1, [SPI_WRITE,$20,$FF] 'RXM0SIDH_REG $00 $FF
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$21,$FF] 'RXM0SIDL_REG $00 $FF
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$00,$0C] 'RXF0SIDH_REG $00 $0C
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$01,$0C] 'RXF0SIDL_REG $00 $0C
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$04,$0C] 'RXF1SIDH_REG $FF $0C
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$05,$0C] 'RXF1SIDL_REG $FF $0C
HIGH 11
PAUSE 10
'********************** RXB1 MASK/FILTERS *********************
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$24,$FF] 'RXM1SIDH_REG $FF $FF
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$25,$FF] 'RXM1SIDL_REG $FF $FF
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$08,$00] 'RXF2SIDH_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$09,$00] 'RXF2SIDL_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$10,$00] 'RXF3SIDH_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$11,$00] 'RXF3SIDL_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$14,$00] 'RXF4SIDH_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$15,$00] 'RXF4SIDL_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$18,$00] 'RXF5SIDH_REG $FF $00
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$19,$00] 'RXF5SIDL_REG $FF $00
HIGH 11
PAUSE 10
'****************** MODE SELECT / EXIT CONFIG ****************
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$0F,$00] 'LISTEN $60 / NORMAL $00
HIGH 11
PAUSE 10
'************************** READ BUS **************************
READ_BUS:
LOW 11
'SHIFTOUT 9, 10, 1, [SPI_READ] '$03
SHIFTOUT 9, 10, 1, [SPI_RD_RXBUF] 'RXBUF $90
HIGH 11
PAUSE 10
LOW 11
SHIFTIN 8, 10, 0, [CAN_DATA]
HIGH 11
PAUSE 100
SEROUT 7,16468,[254,128]
SEROUT 7,16468,[" CAN DATA "]
SEROUT 7,16468,[254,192]
SEROUT 7,16468, [" ",DEC2 CAN_DATA," "]
'**************** ENTER CONFIG TO CLR CANINTF.RXnIF ***********
LOW 11 'CS
HIGH 11
PAUSE 10
LOW 11
SHIFTOUT 9, 10, 1, [SPI_WRITE,$2C,$00] 'CANINTF_REG CLR RX0IF / RX1IF
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
GOTO READ_BUS
Thanks again.
' {$STAMP BS2}
'[ REQOP MODES ]
'[ SPI Commands ]
CAN_DATA VAR Byte
CAN_START:
HIGH 11
PAUSE 10
'LOW 11 'CS
'HIGH 11
'PAUSE 10
' V1
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11 'V1 V2
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
READ_BUS:
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 100
LOW 11 'CS
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
LOW 11
HIGH 11
PAUSE 10
GOTO READ_BUS
Thanks again.
