Quad MOSFET IC suggestions for pager motors?
Hey Everyone,
Ive been working on a project that uses 4 little pager motors (3V) that Im currently controlling using four distinct MOSFETs and flywheel diodes. Id like to reduce the number of components and find a single chip with 4 MOSFETs built into it, but Im having a hard time finding a SM chip with 4 distinct MOSFETs . Does anyone have any suggestions? The motors only spin one way so I just have to be able to turn them on and off. Thanks!
Dave
Dave
You need to provide more information:
2. What voltage are you driving the gates with?
3. Can all four motors run at once, or just one at a time?
Yikes! those DIPs are expensive, you just ruined your average.
Sorry, the motors could be all used at once (PW @100%) so 4 motors running at 3V, 90 mA max (360mA)
Dave
Dave
http://www.mouser.com/ProductDetail/Diodes-Incorporated/DMN63D8LDW-7/?qs=%2fha2pyFadugzu5ZdZZl5NwG70OSSEyB0c4VUEWk5dSpCsAKh5nILnQ%3d%3d
Here is a 7 array, so maybe you can use the other 3 for something else
http://www.mouser.com/Search/Refine.aspx?Keyword=ULN2003LV
Thanks again everyone!
Dave
One caution, the generic ULN2003 part code is a Darlington-Array, so has higher VSAT than MOSFETS, but there are vendors offering MOSFET equivalents.
examples are TI's DRV777 and TPL7407L & TI also uses suffix of LV and V12 for MOSFET alternatives.
(ie ULN2003LV (above) and ULN2003V12)
These 4 parts have varying Vmax and RdsON & switching thresholds, so you can choose the best part.
The TPL7407L is smarter, with level shifting, so can drive fully from 1.5V in, but that gives a modest Iq and a somewhat higher price (higher voltage and higher current)
You can parallel pins, to lower the voltage drop if you have some spare.
These parts include clamp diodes.
