Copter yawing to the left
So i finally got my elev-8 flying again thanks to Ken and my buddy alex with his awesome 3d printing skills...ill make a post for that later.
However, now that i have my elev-8 in the air again, it seems to yaw to the left ever so slighty. I did a test a few minutes ago....I got it about 50 feet in the air and just let it hover with my hands off the sticks.....and very very slowly it yaws to the left.....about a minute in, its 90 degrees and another minute it will be 180.... I thought that my controller might be screwed a bit since ive been flying my zagi lately....but alas, i had it on the right model and it just wont stay still.......any thoughts out there?
I made sure my trims were centered and i have no subtrim set.
Now, the there are a few slight differences between how it was and how it is now...
i now have the blue motors that you can buy off the Parallax website ( did have the yellowish ones) I did all of the programming and calibrations for each motor...
i used to have the battery mounted under the hoverfly board, but now its mounted dead center on the bottom of the copter.
I used to have the rx on the edge of the airframe on the right side...now i have it velcrowed on the upper rear of the airframe...
Any thoughts???
Any thoughts???
I suspect some calibration is required for the gyro. But, without firmware that supports it, it isn't possible.
Jason Dorie's firmware does have a gyro calibration routine that works with 'ground station' software. I believe the gyro behavior is temperature dependent and the calibration attempts to find what that is. You then plug values into the firmware.
To get solid yaw stability might require a different control scheme. A gyro is said to provide good short-term information, but requires a long-term sensor to reference. For pitch and roll an accelerometer does the trick. I suppose for yaw, a compass would be needed
-Russ
My originals are a little beat up, but are hanging in there pretty well. I also have a set that came with the crash pack. The weak point on these seems to be the 4-40 threads. A longer screw with a nut or a helicoil are options I've considered.
-Russ
The QuadX software I wrote has routines that compensate for the temperature drift effect. The numbers are different for every gyro, so you need to calibrate your own machine. It's not a difficult process, but it's not as "plug-and-play" as I'd like it to be.
Jason
Looking over the instructions, any vibrations on the copter can interfere
with the gyros. Having read that, I looked over the copter, and found
many places mechanical dampling could be used. In industry, they use
some devices to detect extraneous mechanical vibrations.
With that, I wonder if a propeller could be used with some transducers
to detect vibrations that could alter the flight path?
