Spin Code for Flexiforce Sensor — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2014-11-15 18:45 in Accessories
Does anyone know if there is Spin or SimpleIDE C code for the Parallax Flexiforce Sensor?
  • JonnyMacJonnyMac Posts: 9,649
    edited 2014-11-15 10:03
    This should do the trick -- I use this for reading a similar RC circuit in a commercial product. You will probably want to filter the result.
    pub read_pot(p)
    '' Reads RC circuit on pin p
      ctra := (%01000 << 26) | p                                    ' ctra in pos detect mode
      frqa := 1
      outa[p] := 1                                                  ' charge cap
      dira[p] := 1
      waitcnt(cnt + (clkfreq / 500))                                ' wait 2ms
      phsa := 0                                                     ' clear counter
      dira[p] := 0                                                  ' allow discharge
      repeat
      while (ina[p])
      ctra := 0                                                     ' disable ctra
      return phsa
    My version specifically tested with the Flexiforce. It is essentially the same as Jon's in function but uses the RCTime liberry.
    OBJ
      pst        : "FullDuplexSerial"
      rc         : "RCTime"
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    PUB Go | Sense
      pst.start(31, 30, 0, 115200)
      repeat
        rc.rctime(0, 1, @Sense)           ' Flexiforce to pin 0, read rc
        pst.Str(String("Value: "))
        pst.dec(Sense / 100)              ' Display rc time decay in Sense var
        pst.tx(13)
        waitcnt(clkfreq / 2 + cnt)        ' 1/2 second delay
    Do you have a Propeller board with an ADC input? If so, you can use the Flexiforce as you would any variable resistor for ADC. For PropC, you could use any of the examples Andy has done that use the ADC inputs of the PAB or PropBOE. Go through the Learn examples -- the latest are on learn.parallax.com.
